Results 1 to 8 of 8
    dewm1's Avatar
    dewm1 is offline Save time, see things my way!
    Nov 2005
    Airdrie Alberta
    Tail Lights ? Dis-assembly ? Help please.
    Some time ago I put a set of Hemi tailights in my 300 Limited and did some creative wiring for the brake lights. Now I would like to do some painting,,, inside the assemblies, just to make them a little different from all the other Hemi lights out there. I've thought of painting the outside, but that's been done.
    I remember seeing some posts on baking the tail lights some time ago,, with varying results and opinions on the subject.
    Now I can't find the posts/threads. I'm beginning to wonder if the threads were in a different forum.
    If anyone can point me in the right direction, I would surely appreciate it.
    Thanks folks,,, have a great weekend!
    David.
    '05 300LTD Dark Lava Red.
    http://dewm1s300.shutterfly.com/
    xxxlblackmag is offline The Exhilaration from Acceleration
    Sep 2008
    MileHigh City, 5280 to be exact
    200 degrees for 10-15 min should open them right up, at least thats what it took for my headlights to come apart...
    **05 BB AwD Magnum R/T
    Maistro69 is offline Obama SUCKS!!!
    Nov 2007
    Certified liberal hater
    not to discount what black mag is saying but just recently I read in the AAC forum that the tailights are actually glued together. A member had a small write up about getting them apart. hopes this helps
    I'll keep my money, guns, and freedom, you can keep the change.
    Sep 2008
    Quote Originally Posted by Maistro69 View Post
    Never took apart taillights so I was not aware they are glued. Good to know
    thanks
    dewm1's Avatar
    Nov 2005
    Airdrie Alberta
    AAC forum? could you post the link?, I've tryed searching and end up with a whack of links, nothing automotive related.
    Thanks for the help.
    David.
    kevdupuis's Avatar
    kevdupuis is offline OT on the RT HID's
    Belleville, On, Ca
    Actually since we build the tail lights I can tell you that they are vibration welded together and the only way to take them apart is to either cut or break them apart, heat will only warp or melt the acrylic lenses.
    Permanently politically incorrect
    pigpen's Avatar
    Minnesota
    I was going to say I thought they were plastic welded.
    I could be wrong.
    dewm1's Avatar
    Nov 2005
    Airdrie Alberta
    Rats,, oh well. It was a thought.
    Thanks.
    Another thought, seeing as how you build them, how about selling me a pair that are not welded together yet?
    Thanks,
    David.
    Quote Originally Posted by kevdupuis View Post
    David.
