WTF! I got 34 lbs in each tire, the gauge cluster works great, Anybody buddy know why I got a TPM warning. I want that to say "System OK".
Jim "Meister" Edwards
RIP "SLICK"
Mine does that about 1 minute into each drive as well. Something I should hit the dealer up on?
"check TPM system" warning message means the WCM (wireless control module) has detected a system fault. see your dealer, he has special tools designed to diagnose this system.
I got the same thing after rotating the tires. It would go on after 5-10 minutes of driving. If I check again, it says system ok.
2005 Inferno Magnum R/T AWD traded
2007 BSM Charger SRT8 traded
2008 BSM Jeep GCSRT8: Option Group I and II.
RIP "SLICK"
Thanks Marc, It worked fine tell yesterday, the wire harness was in for 2 weeks now. Ill have JonW take a look thanks.
RIP "SLICK"
I have been getting this error too lately. I need to take her in anyways since my drivers seat does not move
Chris.....did you guys take the nose off when you did the motor?Did you remember to mount the sensor pickups back to the wheel well lip?
BFNY PERFORMANCE
RIP My Friend
Exact same thing happened to me on the way back from ETown this weekend. Kept getting TPM alarms, yet the readings on each sensor were normal.![]()
Try letting about 5 lbs out of each tire, pumping them up to about 40 psi, and then let air out until you return to the pressure you want. Sounds crazy, but it worked...
Brilliant Black '06 Magnum SRT8 • FRI 'Street' heads, ported intake & Tomahawk cam • MagnaFlow HF cats • B&B cat-back • B&G Stage II
The Iron Mistress Galleries
R.I.P. Dave...
Thanks guys, Funny thing today the warning is gone, I assume alls plugged in ok as the readings are all there. Well see, If this is the only code Im getting I actually feel blessed.
RIP "SLICK"
