Page 3 of 4 FirstFirst 1234 LastLast
Results 31 to 45 of 47
Like Tree6Likes
Thread: suspension source?
  1. #31
    HBADGE's Avatar
    HBADGE is offline .357
    Winnipeg, MB, CA
    Subscribed!
  2. #32
    JbHemi's Avatar
    JbHemi is offline LX Guru
    Dec 2007
    Nyc
    Quote Originally Posted by bfunk04 View Post
    There's no reason why there should be any issue. They use stock mounting locations so it should be fine.
    Awesome. I intend on doing this soon. Pitching my penny's =].
    The 1 everyone loves to hate
    2007 Dodge Charger R/t Matte Black,LMI legmaker TRUE CAI ,SLP LM2,6k HIDs 10k Fogs,JBA Shorties ,Red/White Halos,Black viper rims,Billet Catch Can,EGR Delete,Diablo Trinty,,Razors edge strut tower,Sidewinder cam,Slp underdrive pulley,Magna High flow cats,6.1 valves an rods,GTP Stage 1 head Milled ,3.06 rear,Custom tune from the TOONA himself
    www.queenzdipped.com
  3. #33
    boggart's Avatar
    boggart is offline LX Guru
    Pittsburg, KS
    Just ordered these today. We shall see how it goes.
  4. #34
    JbHemi's Avatar
    Dec 2007
    Nyc
    ^^ let me know how they work out man. Congrads.
  5. #35
    JbHemi's Avatar
    Dec 2007
    Nyc
    Quote Originally Posted by boggart View Post
    how did everything work out buddy?
  6. #36
    dwhip's Avatar
    dwhip is offline DMV SLEEPER
    Jan 2008
    VA, but born in that 202 SW
    Quote Originally Posted by JbHemi View Post
    X2!!!!! I have been looking at these for awhile now. I know they dont ride as good as KW or BC coilovers but i wonder if they ride better then the stock suspension?
    JbHemi likes this.
    All performance work done by mdmperformance.com
  7. #37
    Chuckinnj is online now Are we having fun yet???
    Mar 2011
    Central New Jersey..... Hunterdon County
    Any coil overs will ride better than a stock set up. I installed the BC's on my Charger and went with the Eibach adjustable UCA's and the ride/handling is like night to day. The BC's have extensions for rear shock adjustments and appear to be well made....... Time will tell.
  8. #38
    boggart's Avatar
    Pittsburg, KS
    i just installed today so far so good. rides great. smashed my hand so typing is hard. i'd recommend based on initial impressions. ride like my STs did on my magnum. Great value if you don't need dampening adjustability like most of us don't.
  9. #39
    JbHemi's Avatar
    Dec 2007
    Nyc
    So you give it a what on a scale of 1-10? How was install? What tools where needed ? An how low did u adjust it ?
  10. #40
    boggart's Avatar
    Pittsburg, KS
    For my needs, it's a 10 out of 10. But, I only wanted lower and new shocks. For those that want to adjust dampening, they wouldn't be a 10 and i admit that. And value is very important to me. The ride is amazing, just like all coilovers should be. Install was pretty straightforward. Only one snaffoo.... I broke my finger when I was holding the control arm and taking out the bottom strut bolt. It was my own damn fault, but still.... Live and learn.
    A buddy helped me do it in his Air Conditioned garage and we took all day 8-4. But also made parts runs, test run after doing the rears, etc... Best to plan for a full day if you're doing it at home.
    I had nivomats on the rear, and getting those shocks off was a pain because they won't compress at all. There are two ways to do the back, you can either drop the entire cradle, or you can drop the lower control arm. I did the lower control arm, some say that's the harder way, but actually, it wasn't bad at all.
    Tools, I used air tools, and highly recommend that. I used only 1/2" drive metric sockets ranging from size 15 thru 21. Both a 4" and 10" extension were pretty handy to have. Screwdrivers or a PB12 bar for lining up bolt holes, etc... Rented a Spring compressor and pickle fork at auto zone, get full refund when you return them. 2- 2and1/4 ton jacks, 2 jackstands (to do both front or both rear at same time), razor knife to cut original dust boot off of strut mount for the fronts, tape measure to calculate and set ride height. And a small metric allen wrench to tighten the strut adjustor. Oh, and did need an adjustable wrench for the large bottom strut nut that replaces the original. I'm pretty sure that's it on tools. Pretty basic and not too many really.
    Fronts are definitely "easier" than the rear.
    To adjust it I first measured the wheelwell opening at each tire. 2 methods to do this, floor to wheelwell if you're on nice flat level surface with equally aired tires, or center of center cap to wheelwell opening. I wanted to lower 1" in rear, and 1 and 1/4" in front. I looked at the drop ranges on the website for the new springs, and just raised the adjusters the appropriate amount to leave the drop I wanted. Take your time think long, think twice, do it only once. I you have the tools and patience it isn't bad at all. I suggest having someone to help, so when you crush your hand between the strut and control arm and break your finger, there is someone there to hand you the tools you need to pry the strut off you. =) LOL
    Freedom likes this.
  11. #41
    Dabits's Avatar
    Dabits is offline LX Guru
    Jun 2009
    Calgary, AB
    I bought a set of these at spring fest this year. Finally got the rest of my ducks in a row, along with the coilovers I picked up a 3.73 Getrag, and an Edge TC. I finally got my 226mm half shafts and now I'm just arranging a time for the big install. Do it all at once was the plan, and its been killing me to have half the parts just sitting collecting dust.
    I'm very interested to see how they handle, I'll post back here once I get everything in.
    Mods: Mopar CAI, SLP Underdrive Pulley, Milled Performance Heads & Spartan Camshaft from Inertia Motorsports, JBA Shorty Headers, Magnaflow Catback & High Flow Cats, 3.73 Getrag differential, Edge High Stall Torque Converter, Zex Nitrous Kit & Street Edge Coilovers. iPad dash mod
  12. #42
    KYRedRocket is offline LX Newbie
    Aug 2012
    So after a month or so how would you rate these? Still a 10? Also, are you using OEM wheels? Any before/after pics?
    After reading through this thread and needing to replace the front and rear this has me thinking. I'm not going to the track/strip, no need to do that much adjustment.
    Thanks!
  13. #43
    boggart's Avatar
    Pittsburg, KS
    I do still rate them the same. I haven't had any clunking, noises of any sort, or anything. Well other than the sound of the front cradle freaking bottoming out everywhere I go. LOL.
    I'll try to piece together a before and after. Haven't really cleaned the car other than drive thru car washes because of the broken finger, and then had hernia surgery the next week, so washing the car for proper pics hasn't happened. LOL
  14. #44
    boggart's Avatar
    Pittsburg, KS
    Here's a before and after. Similar levels of dirtyness:
  15. #45
    Montreal300's Avatar
    Montreal300 is offline Go Faster with Class
    Sep 2009
    St. Lazare Quebec
    That looks pretty damn good. What's the color of the car? Looks different somehow.
    Pedator, CAI, MDS indicator, ESP/BAS defeat switch, Tranzformer, blacked out wire mesh grille, smoked and flashing side markers, 9005 2400k 65W fogs, Euro rear fogs, debadged and demolded, 255/45/20 Nitto 420's, Boss 338 wheels, painted calipers. Glovebox & cup holder LED Mod. Blastin Bob 6db reso delete pipes. Euro LED side signal repeaters, 55/35 window tint, BT catch can. Color matched tail lights. Custom front lip. LED interior lighting.
    Next: Lower with BCR Coilovers.
