Results 1 to 15 of 23
    ZMagnum's Avatar
    Tucson, AZ
    Thumbs up Stock Airsilencer Removal.
    I finally got around to removing my stock airsilencer. It's just another restriction and I'm running an Airaid CAI so there is really no need for it. I've heard that certain models and newer models don't have this installed at all. If the factory is deleting it then I don't see any reason that I shouldn't do the same. Besides, I have a new rule, if it's ugly it comes off the car.
    I bought some new plastic ramps from Checker Auto. $39.99.
    It got a bit scary. They slide on my garage floor. I had to put some rubber toolbox liner under them.
    Removed the front shroud. Really easy. Just some screws and push rivets.
    I followed the instructions in the KB and removed the airsilencer. Again, very easy. One screw this time. How ugy is this?
    Here is a view from above looking down.
    Here is a view from below looking up.
    Then I took it one step further and removed this. It's the lower grill shield on the driver's side (airbox side). This blocks fresh air from getting up to the airbox. Easy removal with push rivets.
    Lower grill shield in place.
    Lower grill shield removed.
    I took it on a drive and got up to 80mph. No flapping or extra noises due to this mod. Seems like a good mod. Otherwise I don't see where fresh air is going to come from. It's pretty much sealed under the airbox.
    Sound wise it seems about the same as before although I've not run it with my window down yet. I just got my driver's side window re-tinted (scratches on old tint) so I can't roll it down for a bit.
    my car never came with one, so it would seem to be a safe mod.
    ZMagnum's Avatar
    Tucson, AZ
    Quote Originally Posted by 65standard
    Yeah, I thought I saw you post that. Go back and look at my pics. I've added some and fixed the first one.
    MooNDoGGie's Avatar
    MooNDoGGie is offline Absent From Malaise
    Cambridge, Ontario
    I did this mod when I installed my Weapon-R. Haven't had any problems with it as far as rain is concerned.
    ____°º©Mo0NDoGGie©º°
    PERFORMANCE MODs: kw coilovers,zoomers exhaust,jba shortie headers,diablo predator,hammer h.o.CAI,power slot rotors,hawk pads
    COSMETIC MODS: 20" zinik's,msrt8 front fascia,colour matched fog light bezels & rear wing,shaved front badge,6000k HID headlights & foglights,shaved & debadged,tinted FOG tail lights
    INTERIOR MODS: nav radio,msrt8 kicker sub-woofer,T-handle shifter knob & leather boot,BT aluminum dash knobs
    ZMagnum's Avatar
    Tucson, AZ
    Quote Originally Posted by MooNDoGGie
    Between the CAI filter, height of the airbox and the shroud I don't see how water could travel up there.
    It's good to hear that there haven't been any issues with this.
    I was thinking about putting a hose from the lower grill up to the airbox but maybe next time. I want to see how this works out first.
    Also, I noticed a spot of rust under there. I cleaned it up with some steel wool and painted it with touchup paint.
    MooNDoGGie's Avatar
    Cambridge, Ontario
    Ahhhhhhhhhh the deadly rust spots. I found one on the triangle at the end of the passenger side rear window the other day. Atleast that part can be removed and replaced if it gets outta hand!
    ZMagnum's Avatar
    Tucson, AZ
    As dry as it is here I shouldn't have to worry about it. No salt on the roads, no snow either.
    teezy is offline LX Newbie
    Apr 2006
    that silencer is huge.. i'm going to check if mine has one soon. thanks for the pics
    Teezy.. aka Mr.707
    06 Charger SXT -=[a work in progress]=-
    Brilliant Black
    De-Badged
    ZMagnum's Avatar
    Tucson, AZ
    Quote Originally Posted by teezy
    Sure.
    You probably don't have one. You can tell w/out having to remove the shroud. Just open the airbox and shine a flashlight down through the hole. If it's open you don't. If you see plastic (shallow) then you do.
    monkey's Avatar
    monkey is offline WHY YES I AM A SUPPORTING VENDOR
    Minneapolis, MN
    ahhhhh crap....I had the whole nose of the car off yesterday swapping the grill and I even looked at the intake tube and thought nothing of removing it. I was too focused on the task at hand...wish I had seen this post earlier
    now im too lazy to crawl under there after it.
    MODS: Borla 112 exhaust•SRT8 suspension•Hotchkis swaybar•K&N drop-in filter•35% Tint•Auto Headlights•Chromed R/T rims•SRT grill•SXT Headlights•Daytona chin spoiler•300C interior door pulls•Custom "Monkey" leather armrest.
    COLOR MATCHED: Custom engine cover•Air box•Shock covers•radio/shifter bezel•shifter•rear spoiler•lic. plate frame•splash guards•
    ZMagnum's Avatar
    Tucson, AZ
    Next time you have some energy it's a good thing to do. It was sooooo easy to remove.
    Quote Originally Posted by monkey
    Mosie's Avatar
    Mosie is offline I’m only Blue. Ask someone else...
    May 2004
    Nor Cal baby!!
    Thumbs up Good Mod!
    Quote Originally Posted by ZMagnum
    Yeah, not hard at all.
    Good write up ZMagnum! I haven't seen this before...
    When I put the SRT fascia on my Magnum, I HAD TO remove the air silencer. The SRT belly pan has to replace the R/T one as it’s about an inch longer to mate to the underside of the new fascia, and it has the break ducting built into it. That break ducting runs thru where the lower part of the air silencer sits. Or used to sit.
    SO... it's clear that the SRT8’s don’t have the air silencer. And if you want that aggressive SRT8 look, you have to loose the air silencer. Not a big deal at all.
    I have not had any issue with having mine removed. And like ZMagnum, I also removed the lower grill shield on the driver's side. I feel it really opens up the amount of fresh cooler air that you can get into the air intake area.
    - Cheers -
    M o s i e
    Hello, my name is Mosie and I’m an LX-O-Holic!
    ZMagnum's Avatar
    Tucson, AZ
    Thanks Mosie. I've since added a ram air intake. Still no issues at all with the rain we've had here and all.
    Quote Originally Posted by Mosie
    primetime1267's Avatar
    primetime1267 is offline Pure HEMI!!
    Sarasota, Florida
    I'm a former Mustang racer, and that was one of the first mods we used to do with our Fox-body stangs.. It really does help.
    It's probably one of the cheapest/free mods that any V8 owner can do.
    ZMagnum's Avatar
    Tucson, AZ
    Quote Originally Posted by primetime1267
    It's such a good mod that even Chrysler is doing it. Newer models no longer have it.
