can anyone tell me how to remove the silver inserts on the magnum steering wheel
seems like they are glued not sure though??? thanks
I think they are just held in by two tabs on each side.
2005 Magnum SXT AWD - Inferno Red
Mods: Diablo Predator, JBA headers, Zoomers single exhaust, K & N Aircharger, KW coilovers (variant 2's), 402 Motoring tinted tails, lots of Billet Technology stuff, real walnut dash kit, MOPAR on-dash nav, NC-SXT original honeycomb grille, Jina's Embroidery custom headrests.
held in with tabs i usually use old feeler gauges to pop them out
r u guys sure as the inserts continue behind the main wheel part and i am afraid that they will snap
if i pry to hard on them as i have tried already to remove but they dont seem to want to budge!
thanks jeff
remove the airbag just to get the silver inserts out?? wow sounds like to much hassle as i just want to paint the inserts! maybe easier just to take out the whole wheel?? thxs jeff
If you're talking about the two silver pieces at the bottom of the wheel you should be able to slip a credit card (or feeler gauge as suggested) under the outside end and they slide right up pretty easily.
To remove the top two (with the buttons), you'll need to remove the airbag to get something underneath them and pry them out.
I notice though that you have an '05. Did you buy it used? If yours is like my brother's, it didn't come with those silver inserts on the bottom 2 spokes of the steering wheel and it could be that somebody else glued a couple of them on.
-------------'06 Inferno Red Magnum R/T-------------
the inserts are on the top two spokes and they are stock
no buttons involved
Well, the bottom ones on the '06 and later cars come off very easily so I'm guessing that the top ones on a non-EVIC car are glued on or fasten similarly to the button housing.
I'd go ahead and pull the airbag off (be sure to disconnect the battery and wait at least 10 minutes) to see if you can figure out how they attach. If they use the same basic wheel for all cars, then it's probable that the upper inserts fasten similarly to the buttons and you can pry them out from the bottom. It takes a bit of force, but it will help if you can slip a thin screwdriver along the sides and push them in to help free it up.
