Results 1 to 15 of 22
    madjeff22's Avatar
    madjeff22 is offline "MAD HEMI"
    May 2005
    San Antonio TX
    Steep Hill Problem
    I don't know if this was normal or not, but I was on my way home from the park with my son, and I was pulling out of the parking lot and was on a steep up hill and I let my foot off the break and the car started to roll backwards. Evey car I have owned has been an automatic and they haven't rolled back like that before, it felt like I was driving a manual. Just wondering if this is normal with are cars.
    2008 Brilliant Black Crystal Pearl Coat Charger SE Plus
    1. MOPAR CAI
    bravid is offline LX Padiwan
    Dec 2004
    Lancaster, PA
    Mine does this as well.
    2006 Magnum RT
    67alecto's Avatar
    67alecto is offline E skeud teñval tourioù gell
    Missouri
    All of my cars would do that, depending on how steep the hill was. There's an intersection in Branson, MO (which if you haven't been there, is basically a series of ravines and "hollers" with roads at the top) where it was like you're driving a stick. If you took your foot of the brake to go to the gas you would roll into the car behind you. You had to have one foot on the brake, one on the gas.
    "Walkin' the thin white line on this smiling road. 40 days, I've been all alone. Draggin' my heart all across this world. I got 100 miles to go before I get back to see my girl. Aint got nothing, I got nothing to lose. I keep walking away these blues. The cup is broken, but it's half full. I got 100 miles to go before I get back to see my girl."
    100 Mile Blues - Scott Keeton and The Deviants
    madjeff22's Avatar
    May 2005
    San Antonio TX
    This is my fourth car and this is the first one that went backwards on a hill. At leat I found out about it when there was no cars behind me.
    1. MOPAR CAI
    gn300's Avatar
    gn300 is offline Tipmaster G
    Nov 2004
    Nova Scotia canada # 1313
    Just a thouight, but is the car not in 4cyl mode at idle so there is probibly not enough power to hold it?
    Midnight Magnum's Avatar
    Midnight Magnum is offline LX Newbie
    Jun 2005
    Miramar / Davie FL
    maybe the mercedes tranny is a whole different beast from what we are used to in the american cars?
    Jason
    Current ride: '98 Cobra
    Wish List: MSRT8 with a sunroof
    LouieLouie's Avatar
    LouieLouie is offline Mag-niac
    Jun 2005
    Charlotte, NC area
    I had a 96 Firebird with V6/auto trans, and it would do this only with the "second gear start" button pressed. That made sense, because in 2nd gear there would be less torque available. Having said that, I noticed that my new Magnum (SXT) behaves differently. Where the Firebird would require only a little gas pedal to jump, the Magnum seems to have to "wind up" more before the power gets to the back wheels. Almost like the torque converter slips more than my old car. Since several others have experienced this (myself included), it's probably just the way it was designed. Or maybe it's something as simple as idle speed?
    Lou from SC/NC
    2006 Magnum SXT
    Sunroof, Boston Acoustic 6-speaker system, Mopar/Borla dual exhaust, hood struts, and de-carbonized valves!
    poliojoe's Avatar
    poliojoe is offline LX Newbie
    Arab, Al
    I have a 2005 magnum SXT and it does the same thing. All the other dodges I've owned would hold on a hill. I guess this is my biggest complaint with the car.
    magnum lover's Avatar
    magnum lover is offline Crew Chief for #4 SPO
    Jun 2005
    Conklin, NY
    Mine does it too. Noticed it at an intersection, where it's hard to see anything coming from the right, with a steep grade to it.
    05 Magnum Mineral Grey R/T Hemi Reg# 00310
    http://community.webshots.com/user/magnumlover
    albums with headlight/taillight/bezels & interior changes
    cadzilla74's Avatar
    cadzilla74 is offline Does this smell like chloroform to you?
    Jun 2005
    FTW TX
    gn300, no the car does not activate MDS at idle. Good Lord, drag racing would be totally out of the question for these cars if the first thing you had to do off the line is wake up half the motor. However, I am with the group here that the car does not increase idle speed or torque to maintain position on a grade. It will roll backwards on even a small incline. It's like the computer is saying, this is my idle speed and torque setting for a dead stop. I will maintain this until acceleration is applied. That is all. For all you folks that have been stymied trying to light the tires. This is your time to shine. A slight incline to launch from is a free pass to "smoke 'em" city.
    MaxPowerRT's Avatar
    MaxPowerRT is offline Sniff & Growl
    Nov 2004
    Warwick, PA
    Quote Originally Posted by poliojoe
    This guy is from Arab, Alabama. Hammer has a buddy so close he can smell 'em. :razz:
    There are three ways to do things: the right way, the wrong way, and the Max Power way! **
    ** Disclaimer : The Max Power way is the wrong way only faster.
    gn300's Avatar
    Nov 2004
    So now i'm really confused about 4cyl mode , is it not a deactivated v-8 until throttle pressure calls for all 8 or around 1700, wait brain fart, its a v-8 untill 1700 or throttle calls for it goes to 4 cyl after right ?I think i'm confused it must be the heat or is it the humidity?
    BBMagnumRTAJ is offline Herbal Arsonist.
    Feb 2005
    Sidney, Montana
    When you are below about 20MPH 4cyl mode does not engage. Only when you are crusing (in drive) will 4 cyl mode come on. The car is in 8 cyl mode on start, idle, and through 1st-2nd gear. Ive only had MDS come on in 2nd gear once (pulling a hill in 2nd, shifted into D, tranny stayed in 2nd for a bit then shifted.
    About the rolling thing, i never thought it was a problem. My 89 Dakota does this (only less because the begining of the torque curve is at 1500RPM's, and peaks at 2000, that and having 3.90 gears in the rear). if we had a taller set of gears it would be so bad, but having 2.82 gears, theres just not enough torque at idle to move this thing up the slightest incline.
    COLORADOMAGNUM's Avatar
    COLORADOMAGNUM is offline I'm not speeding......I'm qualifying
    Lakewood, CO
    My SXT AWD does the same thing.
    2005 Magnum SXT AWD - Inferno Red
    Mods: Diablo Predator, JBA headers, Zoomers single exhaust, K & N Aircharger, KW coilovers (variant 2's), 402 Motoring tinted tails, lots of Billet Technology stuff, real walnut dash kit, MOPAR on-dash nav, NC-SXT original honeycomb grille, Jina's Embroidery custom headrests.
    Rev.Hammer's Avatar
    Jun 2004
    Hunstsville, AL.
    I shoulda read this thread sooner!!
    And the dead shall walk
