Pretty common on old school street cars with headers.
Make sure there is a heat shield on the starter since you've already checked the connections. Are your headers coated? If not it might be an idea. You are asking alot from the starter, it wasn't designed to crank over such a big motor, especially when under strain from the heat, way more heat than when stock I would imagine.
You might want to consider fabricating and installing a more substantial heatshield to give the starter a better chance.
Don
