Results 1 to 9 of 9
    4runner26 is offline LX Newbie
    Dec 2006
    Question Start up issues. (HELP)
    I have a 2005 300c with start up issues. When I turn the key normally it takes 1-2 sec to start, but when it is acting up it takes about5-6 sec. This usually happens after a drive. The first start up of the day is always normal. I have taken it to the dealership 4 times. They replaced my throttle body, fuel pump unit, and purge valve. It has also been flashed.
    I hope this is the right place for this post. Has anybody experienced this if so what did you do? Please Help Me !!!!!!!!!
    MikeEast's Avatar
    Ducktown, Georgia
    Something hogging the CAN bus? Is it 100% stock? Aftermarket anything?
    Mike
    Dec 2006
    Bone Stock.
    fnkychkn's Avatar
    greasy cardboard box
    does it take 5-6 seconds after key turn before it starts cranking or does it start cranking right away but takes 5-6 seconds of cranking before it starts?
    Dec 2006
    It cranks as soon as i turn the key. It just takes 5-6 sec. to start.
    fnkychkn's Avatar
    does it happen after a short hot soak (5-10 minute shut down when engine is at operating temp)?
    Dec 2006
    fnkychkn's Avatar
    Quote Originally Posted by 4runner26 View Post
    Yes.
    sounds like a leaky fuel injector flooding a cylinder. they should perform a fuel pressure leakdown test to verify there is a leak. once all other possible causes have been eliminated, they'll need to remove the fuel rail and pressurize the injectors to determine which one is leaking.
    good luck.
    Dec 2006
    Thanks for the info.
