Results 1 to 7 of 7
Thread: Speedo
    cluv's Avatar
    cluv is offline Magnum Aficionado
    May 2004
    Irving, TX
    Speedo
    I have a question for you guys who like to crunch numbers. I've been wondering this for a while, so here goes............................
    I run a 245/40/20 tire on the front, and a 275/50/20 on the back. The 1010 Tire calculator says at actual "60 mph" I'm actually going 61.9 mph with the front tires, and 55.7 mph with the back tires. So my question is............How fast should my speedo show at actual 60 mph?:confused:
    I haven't been able to have any tire shop tell me exactly, let alone even offer a guess. I usually get the "It's hard to say..........." type answer.
    I would just like to know, so when I'm on the highway cruising I don't have to worry about tickets and stuff like that.
    Any help would be appreciated!:D
    da BoMM's Avatar
    da BoMM is offline Conspicuous Combustion . . .
    Spring, TEXAS
    Quote Originally Posted by cluv
    I'm gonna guess that the back wheels (drive wheels) determine your speed.
    6.1L HEMI #622 '07 TorRed MSRT8 1/165= TORRED >< 6.1L HEMI '10 Silver Jeep GC SRT8=4X4JET
    MSRT8 owners http://www.lxforums.com/board/groups/magnum+srt-8+owners/
    Banshee's Avatar
    Banshee is offline Southern by the grace of God
    East Tennessee CSA
    :D
    both the front and rear wheels will be travling the same MPH, just the RPM will be differant
    Those who beat their swords into plowshares usually end up plowing for those who kept their swords
    mnunes's Avatar
    mnunes is offline That guy
    Jun 2005
    Fountain Valley, CA
    I think it depends on which wheels are used for the spedometer. Since the car's traction control has to have sensors at each wheel, it could really be any of them.
    If a front wheel is used for the spedometer, your spedo should read 58.2 at "real" 60mph. If a rear wheel is used, it should read 64.6 at "real" 60mph.
    LowGo's Avatar
    LowGo is offline Alter ego of MyMaggieMae...
    May 2005
    Gresham OR
    I'm going to venture to guess that the speedo is based on the speed of the drive train... i.e. the rear wheels. In that case, when your speedo says 55.7 mph, you're doing 60 mph.
    Inferno Red '05 Magnum RT AWD - Who says the AWD sits too high?!
    German influenced garage queen .................... German engineered daily driver
    da BoMM's Avatar
    Spring, TEXAS
    Again, based on the rear wheels, and the info you have is accurate, (55.7 MPH when speedo says 60) when you're going 60MPH your speedo will show about 64-65.
    (MNunes already said it)
    MSRT8 owners http://www.lxforums.com/board/group.php?groupid=24
    LowGo's Avatar
    May 2005
    Gresham OR
    Quote Originally Posted by BragonMyMag
    Nope, nope nope!
    If he used the 1010 calculator correctly, it displays what your speedo will read when you're actually doing 60 mph (based on entering the correct stock tire size). So, in this case, with the rear wheels, his speedo would be reading 55.7 mph when he's doing 60 mph.
