Results 1 to 15 of 16
    DBTDODGE's Avatar
    DBTDODGE is offline BA Wagon!
    Aug 2005
    Surprise, AZ
    Exclamation Small thing, Big problem
    About two weeks ago I bolted on some nice 22s. They were balanced by a good shop, had good tires put them, alignment, but I still had a pretty bad vibration. After re-torqueing the lugs with no change, I was about to start over with the tire balance when decided to check the wheel to hub fit. I found that I could get a 0.015 feeler gage between the two about half way around. That equaled about 0.135” of variation at the tread (about the thickness of two pennys).
    The problem was the little spring clips that are over one or two of the lug studs from the factory. The clips are used to hold the break rotor on during assembly at the factory, but don’t do much once the car is built. The way my rims are built, there is little or no counter sinking of the stud holes on the hub side and were not mating properly with the hub face. I removed the clips and the vibration went away.
    Thought I would pass it along.
    '05 RT: Magnaflow Exaust, K&N Typhoon, Intrax ARB (rear), Intrax Lowering Springs, custom Boyd Coddington wheels w/Michelin Pilot Sport PS2 255/30 ZR22
    '93 Lightning: Custom cat-back, K&N, Jacobs ignition, Eaton dif
    createdbyone is offline DodgeMagnum.net Original
    Dec 2004
    Travis AFB, Ca
    You know i saw those and thought the same exact thing but never mentioned it, i know its a problem becuase the neon srt4 guys were having the same problem....sorry about not blurting it out months ago for your sake man
    DBTDODGE's Avatar
    Aug 2005
    Surprise, AZ
    Quote Originally Posted by Timmins02
    That's OK, but, someday, and that day may never come, I will ask you to do me a favor.....:D I've had a lot of cars, and used a lot of after market wheels, and never had or heard of this problem before. Who'd a' thunk it? :???:
    Mr. Magnum Man's Avatar
    Mr. Magnum Man is offline Gone Fishing
    Jun 2004
    Long Island
    10 lashes for you with a wet noodle.
    Rev.Hammer's Avatar
    Jun 2004
    Hunstsville, AL.
    what if he digs that sorta thing?
    And the dead shall walk
    FOHN_JARGO's Avatar
    FOHN_JARGO is offline Ka CHOW!
    Bella Vista Arkansas
    Quote Originally Posted by Rev.Hammer
    Then give him 20.
    The Magnum has a soul. It has a personality, something all too lacking in the automotive transportation appliances everybody else is offering.
    mbkvette is offline LX Newbie
    May 2005
    those retainer clips that hold the rotor on have to be removed on most aftermarket wheel installations. i took them off when i put on my wheels, and i just know from talking to people who put rims on for a living. they serve no purpose anyway once the car is assembled.
    darkrt's Avatar
    darkrt is offline LX Padiwan
    Jul 2004
    Spring, Texas
    A good shop should have removed them!
    diamondrmp's Avatar
    diamondrmp is offline LX Guru
    Northern California
    Thats surprising that your "good shop" didn't know to remove those clips but there is also the problem with wheels being hib centric. If you are still getting a vibration hub centric rings are the fix.
    DBTDODGE's Avatar
    Aug 2005
    Surprise, AZ
    Quote Originally Posted by diamondrmp
    The wheels were installed by me, in the parking lot at SEMA, after the tires were mounted and balanced. Funny how you can plan things for months, but it doesn’t come together until the 11th hour!
    Wise man say, he who plans early, plans twice!
    Vaderwagon's Avatar
    Vaderwagon is offline LX Padiwan
    Marengo, Ohio
    Funny, but CCW addresses this in their technical section. http://www.ccwheel.com/files/technical.php
    Outside of a dog, a book is a mans best friend. Inside of a dog it's too dark to read. -Groucho Marx
    2005 Black Pearl Magnum RT
    Eibachs, SRT8 suspension, K&N CAI, SuperChips FP, Mopar hidden hitch, Blastin Bobs pipes, Kumho STX 255-55-18.
    diamondrmp's Avatar
    Northern California
    Quote Originally Posted by DBTDODGE
    Uh huh so you were tooting your own horn huh? LOL
    DBTDODGE's Avatar
    Aug 2005
    Surprise, AZ
    Not that I'm above such things, but no.
    I recieved the wheels with the tires mounted and balanced; I then I bolted them on. I will say that my Wheel-Bolting-On skills are secound to none, LOL.
    diamondrmp's Avatar
    Northern California
    Which Boyds wheels are those?
    SoCalRT's Avatar
    SoCalRT is offline Major Mag Nut
    Lake Elsinore, CA
    They look like they may by the Gotcha Series Fury wheel.
    Later,
    Brett
