check this out i find this connector and its not plugged into anything its for the side markers whats the deal i couldnt find where it plugged into its wired in series with the sidemarkers.......where o where could the female end be???
MOD LIST : NOT ENOUGH!!
bumpneed help before i can put fascia back on!!
mmm, never seen that wire before. What wiring harness is it connected to? Could you take a further pic of where is is running out of? And is it on both sides?
GoMango ->2197
its wiredto both the passenger and drivers side marker lights its sitting closer to the passenger side
If you have auto leveling headlights, I would have to say I think it is for your headlamp leveling sensor. It may be on the A-arm instead of frame in picture depending on where the car came from.
GoMango ->2197
no i dont this is actually wired into the parking lights imagine the two parkings lights with one connector on it
C103, look for the R. impact sensor, the follow the wiring up the harness until you find the other side of what's on the fascia.
www.ramtruckforums.com
Joint connector C103. Find it and plug it back in already!!!
C103 (LX48) - DK. GRAY (FRONT END LIGHTING SIDE)
1 Z901 20BK/TN
2 Z902 20BK/BR
3 L777 20WT/VT
4 F500 20DG/PK (TIRE PRESSURE MONITOR)
5 L89 20WT/YL (EXCEPT BASE)
6 D508 20WT/GY (TIRE PRESSURE MONITOR)
C103 (LX48) - DK. GRAY (HEADLAMP AND DASH SIDE)
1 Z901 18BK/DG
2 Z902 18BK/LB
3 L777 20WT/VT
5 L89 18WT/YL (EXCEPT BASE)
