Here is a great source for all those considering this Mod. I took the liberty of taking pics while performing this conversion for SRT-BILL. Soon I will install it on his SRT8 Magnum and have it painted black. Enjoy!
This is the stock donor hood from a Magnum, for the Charger it is the same exact process.
Flip the hood upside down and remove the squirter with pliers.
Next, 2" masking tape is put on the areas to mark on the hood. Mark the center line of the hood by measuring as on the diagram, then replace the squirters. Do NOT trust your eyes on this part. If the light source in not directly centered above, it will throw you completely off and look NOT centered when it is or vice versa.
Using scissors, cut on template on the lines, including squirter holes.
Stretch out pattern and tape on in a wagon wheel pattern. Make sure you stretch it tight, the center line is centered, and the squirter align in the holes.
06 Charger R/T Black
