Our car's fuel system in compatible with E-85. Diablo has a tuner in S.D. I think they recommend, that has alot of experience tuning for E-85.
Biggest problem is, there is no sensor in your fuel system to tell the computer what you are running. So you need to have a gas tune and an E-85 tune in your Predator and change back and forth when you change fuel. If you can run E-85 exclusively, that simplifies things considerably. If you don't care about the mileage, E-85 is a great choice for H.P. and a TON cheaper than race gas if / where you can find it.
