If anybody is curious as how the vehicle "de-tunes" itself, it does so by retarding spark timing and adjusting the fuel injection curves. Retarding timing will give you less torque, but will reduce knock (pre-combustion). Adding more fuel will likewise change air/fuel ratio, creating a "rich" condition which also reduces the chance for pre-ignition. That's why you may see a slight decrease in fuel efficiency when you go to a lower octane. The engine is adding more fuel to make up for the improve knock reducing qualities of the higher octanne fuels. This will only work to a certain point and using premium fuel in this car will not improve mileage or performance because the stock computer only works within established perameters. In other words, the stock computer will only advance spark timing and reduce fuel injection to a certain point. This is why we need the aftermarket to step in with some software mods to really adjust the perameters to give us better timing and fuel curves, drastically improving performance, but perhaps neccesitating the need for premium fuel.
06 300C SRT8. Diablo Predator - 91 perf tune; Motorad 180* T-Stat; Frankintake IV w/velocity stack mod, chilly air mod. Soon to add the ONLY Australian Blits Bodykits front end in America. Only 18k miles!
