Any good suggestion here? I do park under a pine tree. Don't have a choice. The hot days leave me coated. The only thing I have found that disolves the sap is Isopropyl Alcohol. Using it much on the finsih concerns me.
Thoughts? Suggestions? Flames?
2005 Dodge Magnum RT - Midnight Blue Pearl
Volant CAI, 190 Thermo, Mr. Grille Vertical Grille,
SXT Headlights, MDS Monitor, Bel 975R,
Infinity 3002cf (dash),Blaupunkt 605 woofer (door), Infinity 6002si (Rear),Infinity Basslink, SC Tuner, GSM Fan/Traction Mod, 22elite Heal Guard, Factory One Tail lights
well the obvious is to find another place to park but since you said you have no choice....
I would invest in a decent car cover. Pain in the A$$ but better than washing and removing tar every few days.
Have you tried peanut butter???
http://www.lxforums.com/board/showth...387#post104387
6.1L HEMI #622 '07 TorRed MSRT8 1/165= TORRED >< 6.1L HEMI '10 Silver Jeep GC SRT8=4X4JETMSRT8 owners http://www.lxforums.com/board/groups/magnum+srt-8+owners/
wd-40 and then a little wax or detailer after. I have the same problem here in NC. Get them before they harden.
WWW.DodgeMagnumGrille.com
I just got a glob somehow. No trees over Maggie....I dont know. I tried Goo B Gone with little success. I then used 3M bug and tar remover. Worked like a champ!
I like to pass!!
The various bug & tar removers usually work albeit with a lot of rubbing, I don't know about the newer paints but pine sap absolutely disolves the older paints. Get it off ASAP.
NC-SXT's got it right - WD40 takes it off like magic...
Brilliant Black '06 Magnum SRT8 • FRI 'Street' heads, ported intake & Tomahawk cam • MagnaFlow HF cats • B&B cat-back • B&G Stage II
The Iron Mistress Galleries
R.I.P. Dave...
I have had good luck using Naptha, available at all hardware stores, also good on clothes. Will not hurt your paint.
Bob
Just removed some tree sap with your WD40 trick. Than used detailer and it did the trick. Thanks
