Page 1 of 3 123 LastLast
Results 1 to 15 of 44
    BlackCharger06's Avatar
    BlackCharger06 is offline Black Charger 06
    Boston
    Remote start stalls out?
    Not sure if this is the right section, but I know most people skip over a lot of posts. So the install was pretty straight forward and worked fine. I get a call today from my mom and she tells me the car dies after about 15/20 seconds. I also like a dork wired it up to the horn so every time she hits the key button the horn honks. So undoing that wire isn't a big deal, but why is the car dying? Plenty of gas, check Could it be the weather? I'm guessing that she is hitting the key to many times and is shutting it down by accident. It could also be just a programing thing as well, I'm usually pretty good when it comes to wiring things up and had it running yesterday just fine. Love to hear any ideas, it's cold out so I'd love to spend only an hour in my drive way instead of 3 thanx guys.
    Brian
    <img src=http://i84.photobucket.com/albums/k8/brian_pahlm/wheels/new_england.jpg border=0 alt= />
    Audio Mods
    Alpine Iva W205 w/ 6 disc changer Alpine pxa-h701 Processor JL audio 450/4 JL audio 500/1 JL audio 10w7 Boston Acoustic SL95's Hertz MLk 2 Componets PowerMaster d3100
    Other mods
    Hood Strut Mod Daytona Grille R/T BadgesRetro Charger Deck Badge Ct Cruzer (Blastin Bob's) Custom Exhaust, What's next????
    glhs837 is offline Power With Control
    Very Southern Maryland
    Brand of remote start? Bypass module?
    Boston
    Quote Originally Posted by glhs837 View Post
    mopar oem for 2006 dodge charger. Install kit and remote start module. Any help would be great. I'm hoping it's just user error or a easy fix. Maybe the doors need to be locked or the gas light was on so it shuts off.
    Audio Mods
    Other mods
    Zoban's Avatar
    Zoban is online now lil Red Wagon
    Feb 2008
    Oshawa Ontario
    May need to reprogram the tach ..
    2006 Lil Red Wagon SXT
    Modlist : AFE Stage II, JBA Headers, Corsa Catback, 20" Vipers, Cross Drilled Rotors, Diablo Bob@SVS Tuned, Pioneer DEH-5000UB, 12" Enclosers, Halos, Low/Fog HIDs, Cuda Grille, TruFiber Chally Hood.
    at the Track
    My Garage
    Mentoria Computer Consulting
    Zoban's Avatar
    Feb 2008
    Oshawa Ontario
    http://www.moparsupercenter.com/pdfs/82208995AE.pdf
    on Page 11...
    3. Tach Rate Programming (Required for system to operate).
    A. Close hood.
    B. Turn the ignition to the “on” position.
    C. Press and hold the programming button.
    After 10 seconds the horn will
    chirp and the lights will flash
    3 times.
    D.
    Release the programming button.
    E. Press and release the programming button again.
    The horn will chirp and
    4 times indicating the system has entered Option
    Bank 1.
    F. Press and release the programming button again.
    5 times indicating the system has entered Option
    Bank 2.
    G. Advance to option 2 by pressing and releasing the brake pedal 2 times.
    The horn will chirp and the lights will flash 2 times indicating the system
    is at option 2.
    H. Start the vehicle with the key.
    once approximately every 3 seconds indicating a valid tach signal.
    I. Once the engine has settled to a normal idle speed, press and release
    the brake pedal to set the tach rate.
    J. Turn the ignition off.
    Note:
    If the system is not chirping the horn and flashing the lights every 3 seconds
    after the ignition has started, the system is not seeing a valid tach signal.
    Check your tach connection (Dk Blue/Yellow at coil). Repeat the
    Tach Rate Programming procedure.
    at the Track
    My Garage
    Zoban's Avatar
    Feb 2008
    Oshawa Ontario
    Or the Keys have to be redone for some reason..
    6. Vehicle starts then stalls - SKREEM Transponder Interface not learned.
    A. Ensure 2 and 4 way connectors are connected
    B. Ensure antenna coil is wrapped tightly around the ignition cylinder
    SKREEM antenna ring.
    C. Re-learn SKREEM Transponder Interface (see page 12).
    at the Track
    My Garage
    Boston
    Quote Originally Posted by Zoban View Post
    Hey man thanx, Bad news I get to figure this stuff out in the snow tomorrow. Good news is I'm pointed in the right direction on how to get it done. It's always something dumb, the hard stuff I can do no problem it's always the little things. Thanx again.
    Audio Mods
    Other mods
    Mr. iNCREDIBLE's Avatar
    Apr 2006
    check your coolant level as well..
    mine has been mis-starting and also dying after 20 -30 seconds and i discovered I had a coolant leak, replaced the radiator hoses and flushed the system and now the remote start fires on every shot..
    not sure if the 2 were linked, but i believe they might have been, and the remote start was killing the motor because the coolant pressure was too low..
    Zoban's Avatar
    Feb 2008
    Oshawa Ontario
    Now that is one you wouldn't think of .. HAL at work protecting itself as always eh..
    at the Track
    My Garage
    Boston
    Quote Originally Posted by Mr. iNCREDIBLE View Post
    This car is to smart for it's own good I'll have to add that to my list.
    Audio Mods
    Other mods
    klarmie's Avatar
    klarmie is offline Like Freedom? Thank a Veteran.
    Sep 2007
    New Hampshire
    I bet resetting the tach signal will take car of the issue
    5.7L Hemi Registry # 00814
    Boston
    Quote Originally Posted by klarmie View Post
    I'll have to go try that next. It works on flat ground just fine but for some reason won't work in the drive way that has a sharp angle. Is there level or a float or something silly that I am over looking. I heard that the coolant level might have something to do with it.. Wtf
    Audio Mods
    Other mods
    Zoban's Avatar
    Feb 2008
    Oshawa Ontario
    DOH .. it's the hood switch .. parked on the angle it thinks the hood is up .
    May wanna swap to the 2009 switch (has resistor in it already) which goes over by the pcm and doesn't rely on gravity and angles as much as the battery shaped one that bolts onto the hood. ..
    at the Track
    My Garage
    Boston
    Well I got out of work late, but I was able to start the car on level ground with 0 problem. I did it 5 times just to be sure. Now when I pulled in the drive way nothing. Then it worked, then it didn't. It must be the hood latch. 9 degrees right now though. I'm going to wait until this weekend when it's a nice and toasty 25 degrees to mess with it some more. (thanx zoban)
    Audio Mods
    Other mods
    Boston
    :0
    So it was on a hill and I was having problems. After watching tv watching the snow I decided to just move the switch which took care of the problem. I tried mounting it where the book says which didn't work out so well. Now it's finally fixed.
    Audio Mods
    Other mods
