Results 1 to 13 of 13
Thread: Remote Start.
    tomsweb1's Avatar
    tomsweb1 is offline 2007 Magnum SXT
    Jun 2008
    Edmonton, Alberta
    Remote Start.
    Hey all! I need help. I want to install a remote starter on my 07 Magnum. I want to know EXACTLY what I need to do it. I have spent a few days phoning installers and dealers, all of whom seem uneducated, or excessively vague (likely a ploy to get me in the shop to pay for service). Any and all input is appreciated!
    Zoban's Avatar
    Zoban is offline lil Red Wagon
    Feb 2008
    Oshawa Ontario
    If you are only looking for a starter and not fancy bells whistles or alarms..
    The Mopar remote is very easy to install and is made for our cars..
    Shoot AdamC eastway a PM for prices ..
    The install pdf is in the knowledgebase as well I believe and if not it's available in pdf on the moparsupercenter site as well so you know what you are looking at before even ordering the starter .. (paper copy comes with the unit btw)
    2006 Lil Red Wagon SXT
    Modlist : AFE Stage II, JBA Headers, Corsa Catback, 20" Vipers, Cross Drilled Rotors, Diablo Bob@SVS Tuned, Pioneer DEH-5000UB, 12" Enclosers, Halos, Low/Fog HIDs, Cuda Grille, TruFiber Chally Hood.
    at the Track
    My Garage
    Mentoria Computer Consulting
    Zoban's Avatar
    Feb 2008
    Oshawa Ontario
    Here is the thread with the install instructions etc ..
    MOPAR Remote Start Instruction Manual
    at the Track
    My Garage
    tomsweb1's Avatar
    Jun 2008
    Edmonton, Alberta
    Sorry Zoban, I should have been more clear.
    I already have a starter that I would like to install, but I am aware that I may need another module or two. I know I need the transponder by pass, and I've heard that I might need another one. I was wondering if anyone knew exactly what they were for, and what they were called, where to get them, how they're installled, or, even, how to tell if I need them.
    Thanks so much!
    Zoban's Avatar
    Feb 2008
    Oshawa Ontario
    Ahh .. in that case we would need to know what starter it is that you have and any additional parts etc that you have now so that we can then go forward saying you'll need XX part etc..
    at the Track
    My Garage
    radioactive's Avatar
    radioactive is offline LX Padiwan
    Sep 2007
    Tullahoma, TN
    You can look at iDatalink and Fortin for the transponder module and the alarm/door lock module. They also have an all-in-one module. We install mainly the iDatalink.
    tomsweb1's Avatar
    Jun 2008
    Edmonton, Alberta
    Ok, The only thing I have is a bulldog starter (model #RS700)
    Will the iDatalink all in one modules do everything I need, or do I need more than that?
    Sep 2007
    Tullahoma, TN
    The iDatalink module will give you: transponder bypass, locks, OEM alarm & disarm,trunk release, door status, trunk status, brake output, tach, panic and radio shutdown(RAP). The model # is ADS-AL CA
    tomsweb1's Avatar
    Jun 2008
    Edmonton, Alberta
    Awesome! But, which of those fetures is what I need to get a starter to work?
    Zoban's Avatar
    Feb 2008
    Oshawa Ontario
    Think radioactive is saying that the module will allow all the above .. transponder bypass is the main issue you'll have the rest is toys .. I could be wrong though as I don't do/haven't done Bulldog starters..
    at the Track
    My Garage
    Sep 2007
    Tullahoma, TN
    Quote Originally Posted by Zoban View Post
    Exactly. I also forgot that you will need the Chrysler ring from iDatalink also.
    tomsweb1's Avatar
    Jun 2008
    Edmonton, Alberta
    AH, ok, and is this rf ring the 'second bypass' the installers have told me about?
    quarky42's Avatar
    quarky42 is offline LX Guru
    Jan 2006
    Las Cruces, New Mexico
    Sorry this is an old thread....I'd like to add some info anyway for posterity (and mainly for anyone searching and finding this later on).
    The ADS-RNG C2 RF Ring is simply a glorified piece of wire antenna *WITH* a chip embedded in it. The chip is the same as in your key... it gets programmed (one time only) to the car and the chip fuses itself so that it can only be programmed to one car. The wire plugs into the bypass kit (ADS-AL CA w/ CH3 or maybe CA firmware) and when your remote start tells the bypass kit to start the car then the bypass sends the wireless RF "key signal" to the security device inside your ignition module telling the car that a valid key was being used.
    In short: The antenna is used with bypass units to authenticate to your car. Without the bypass kit and antenna the car would start and immediately be shutdown by the built in factory security system.
    Did the radiator cap mod: SRT8 is here....
    The Hemi says, "VROOOM!" Hemi Registry #00420
