Results 1 to 6 of 6
    cm2005300's Avatar
    cm2005300 is offline The New "Milli Vanilli"
    Bc
    Really important ?!!!
    i had to replace my rear rotors so i ordered them from advanced auto parts.....when i got the instead of being a single solid rotor they were split in half kind of like you would cut a hamburger bum and had slots....of course these did not fit ....so the guys at advanced auto said that the rotors i have belong on a 300c because my car is an 05 and the slotted ones are for a 300...hahahahhah what ****ing retards work there?? anyway whats the correct one??
    MOD LIST : NOT ENOUGH!!
    cm2005300's Avatar
    Bc
    sp heres a pic i found on this thread of a pair of front and back rotors and i noticed the backs have the space inbetween
    F/S ABS Senors, Brake Lines, V6 Calipers & Rotors
    well now i have a problem because those are what i got and the caliper doesnt fit over then they are too thick.... is it possible somewhere down the line before i got my car someone switched out the larger rear calipers for the smaller front calipers and were using from rotors in the back?????
    Tbird100636's Avatar
    Braintree, Massachusetts
    Exclamation
    Quote Originally Posted by cm2005300 View Post
    No. You have a lowline 2.7L V6 car. The rear rotors are supposed to be solid, not vented. Go back to Advance and throw the rotors at them.
    www.ramtruckforums.com
    Mar 2008
    You have the Vented rotors in the front and the solid, non-vented rotors in the rear.
    Front
    Rear
    PPP stage 3 heads, Howards cam 219/227 .600/.575 112 +4, ported 6.1 intake, MMPG 85mm throttle body, MSD "Blaster" coils, JBA headers & mids, Corsa exhaust, Paramount "Dominator" torque converter & stage 2 valve body, BC Racing coilovers, Eibach sways, BWoody links, Razorsedge brace, 226mm Getrag 3.91 LSD, Wilwood "plus 2" big brake kit by TCE
    Mag05's Avatar
    Mag05 is offline The HEMI that roars
    Jun 2008
    Brantford, On. Canada
    Ouch!!!! "TBird"; Even though you are correct in what you stated, you could have tweaked the "lowline" word abit.
    SLP CAI, SLP Catback, SLP 25% underdrive pulley, 170 stat, Predator SLP tunes[2], Mopar TCM, no esp mod.
    cm2005300's Avatar
    Bc
    Quote Originally Posted by Mag05 View Post
    hah na its cool THANKS EVERYONE FOR YOUR HELP
