Results 1 to 8 of 8
    67charger's Avatar
    67charger is offline LX Padiwan
    Nov 2004
    Gilbert Arizona
    Quick SC Tuner question
    I wanted to use my tuner for the first time today, but I'm at work and left the manual at home. I figure I can just follow the prompts, but I forgot how to get started.
    Is it key off (and door open) or key on before you plug it in?
    FactoryD's Avatar
    FactoryD is offline Gettin' high on the downlow
    Nov 2005
    Phoenix, AZ
    Engine off. Key turned to 'On'. Plug it in and follow the prompts. And the end, hit 'Program Vehicle' and follow the prompts exactly.
    67charger's Avatar
    Nov 2004
    Gilbert Arizona
    Thanks!!!
    cdn2usa's Avatar
    cdn2usa is offline Don't fix what ain't brok
    May 2005
    Midlothian, Va
    Quote Originally Posted by 67charger
    Disable the opition of having assesories operating for a set amount of time when the car is turned off. Or keep the door open with the dome lights off (just a little extra to keep battery drain to a minimum). Then plug in the tuner, under the dash driver's side left. It will tell you when to turn the key.
    Then follow the yellow brick road (the prompts). Since it is your first time it will want to save your stock info.
    Inferno Red R/T
    Fully loaded w/o rack
    Mopar CAI
    Mopar Trailer Hitch
    Borla CatBack
    MDS Exterior Indicator LED
    Interior Fuse #17 Disabler
    HIR Bulbs
    Silver Indicator Bulbs
    Custom Engine Cover
    35% Front Tint
    LX Forum Emblem
    BFG KDW2 255/55/18
    SuperChips Tuner
    67charger's Avatar
    Nov 2004
    Gilbert Arizona
    Guess I'll leave the door open, because I dont think I can change the accessories option with out the evic (I'll check the manual though).
    I wish I wasn't this nervous.
    MattRobertson's Avatar
    Feb 2005
    At the bus stop...
    You can also just turn the radio and the fan off if you are sitting in the car with the door closed. And wait a few secs for the lights to go out.
    67charger's Avatar
    Nov 2004
    Gilbert Arizona
    PANIC!!!
    I had the rdb1(whatever that error message is) error and my car would not start. I was able to go back to stock and it started without any problems. I called SC and they said a release was expected to be available this Friday and to not do anything until then.
    Wow, I hesitated doing it at all, but I thought the no start problem was with the 06 Chargers. SC said some Magnums are affected. I feel for the people who could not get their cars started...my heart dropped when I turned the key and nothing happened.
    Date of mfg 08/04
    PaulFix's Avatar
    PaulFix is offline Mr. White Chocolate P. Rock
    May 2005
    BC, Canada
    I start with the key off, door closed lights and radio off. No problems for me (touch plastic!!!)
    Dodge Magnum RT AWD MDH=Jan 19th 2005 7-8pm
    Tow package, Midnight Blue, Painted spoiler body colour, Auto headlights, HID lows, Fogs on with Hi beams, SC flash with custom tranny and 91 tune, RER MyGig installed, Tranzformer, Resonators deleted, Custom Stainless intake.
    160,000km driven very hard, repairs include replaced front brake rotors and pads $200, rear pads$, ebrake shoes, all 4 tie rod ends $50ea (only 1 was loose), front sway bar rubber bushings $25(first thing to check if front is clunky); 3m refinished headlights WOW $30, 4 sets of tires, 2 tranny filter and flushes,
