Results 1 to 8 of 8
    His 'n' Hearse is offline LX Padiwan
    SE MI
    A question worthy of fnkychkn
    I don't often get the opportunity to use the cruise control on my '05 Mag SXT RWD, but I have and it was fine until it wasn't - like it didn't exist. 7,500 mi on the clock so it's off to the dealer for to exercise my warrantee. Here's what was typed on the service order when I picked up the car:
    "checked and unable to retreive codes and according to star monitor all abs sensors and operating normal monitor input and output from switches and ok checked wires at steering module to pcm wt and lt to wt and lb and ok all wiring ok per star replaced steering control module and still inop, removed steering wheel and module to access and replace cruise switch per star still inop further investigator found pcm mileage at 12,000 miles tcm at 7500 reset both and retested ok"
    The italics are mine and the actual copy was all caps but I didn't want to appear to be yelling.
    So what the he!! does this mean, especially the italicized part? Anybody else had anything similar?
    His 'n' Hearse
    You know that Social Security stuff they take
    out of your paycheck? They're givin' it to me!
    MagnumFreak's Avatar
    MagnumFreak is offline Chasing Dreams
    Jun 2004
    Evans, GA
    One of the many parameters these cars monitor and store in multiple places is the mileage. For whatever reason your pcm and tcm mileage readings where way offset. One of the more interesting parameters I have seen is the originally installed vin and current vin values. Great way to see if your module has been used on another car.
    As far as why it would be way off, not sure on that one. Have you experienced any transmission issues?? I doubt that a tire size change would cause such a significant difference in mileage readings.
    2005 Dodge Magnum R/T
    -Martin Luther King, Jr.
    SE MI
    I ran 20" wheels for the first 2600 miles but the 255/40 Toyo Proxes S/T tires are within 0.1% of the stock 17inch-ers and the speedo is pretty much dead on with both so we can discount wheels/tires
    The car was a 10/04 build and I bought it (supposedly) new from a dealer with like 24 miles on it on 7/31/05. No trans problems (although it shifts really mushy) and mileage has been ok.
    Could this have been a used vehicle with a set back odometer?
    His 'n' Hearse
    Jun 2004
    Evans, GA
    I will hook up my starscan before I go home today and check to see if there is a difference between my pcm and tcm mileage. I doubt there was anything fishy going on at the dealer. May just have been a software problem.
    SE MI
    IIRC, I don't think I had an opportunity to use the cruise control between when I got flashed for pulsating head/dash lights and I found it no workee. Maybe a relationship there?
    His 'n' Hearse
    fnkychkn's Avatar
    greasy cardboard box
    if voltage is detected on T751 circuit (fused ignition switch output [start])(PCM connector C1 pin 30) at anytime other than during crank, the PCM will disable the cruise. this voltage may be caused by an improperly installed aftermarket remote start or a defective diode in starter relay.
    not sure as to why the mileage does not match.
    aries4life's Avatar
    aries4life is offline Goodbye Mag
    Jan 2006
    Georgia
    This is interesting.. quite the mystery. Even if you were running 10" tires (somehow) you'd still have the same mileage reading on both modules. Only way you could have a difference is if the TCM registered rotation and PCM used GPS lol
    '05 Mag R/T - Shaved Ram logo and bumper indentions - Eibach ProKit - JBA Shorty Headers - JBA mids - SRT-8 X-over - Magnaflow muffs - Borla pipes - Zoomers tips - DiabloSport Predator - 170 deg thermostat - Jim Turner Fan Mod - Modded SRT Airbox - Quickest Superstock 5.7L at S.E. Shindig '08 You will be missed... R.I.P. :(
    eng1neer is offline LX Newbie
    Apr 2006
    Didnt see TCM mileage on mine.. the PCM and FCM has it though... PCM was a bit off. Starscan says to verify within 100 miles of actual on odo. FCM and CCM were dead on.
    It's got a cop motor, a 5.7 liter plant, cop tires, cop cooling, cop brakes, cop suspensions, and cop shocks.
