With the predator can you just adjust the tstat temp, shift firmness, and disable the MDS with out putting a tune such as 91 or 93? I would like to keep it stock except for those three area's just mentioned. Thanks guys.
BuR HeMi
not quite sure about the MDS or the tsat temp but yes you can adjust shift firmness without loading a tune...
06 SXT AWD Silver Steele Metallic: Debadged, Demolded, Tinted Front Windows, AFE Stage II, Borla 125 Catback, Air Silencer Delete, Cross Drilled Rotors, Diablo Predator,Hood Shocks, Strut Caps, 6000k LowBeam & Foglight HID's, Lowered on BCR Coil-overs. Mopar Remote Start, Charger Chin Spoiler, Led Tails, and crazy nut behind the wheel...
you would only want to lower the fan settings if you have a lower t-stat installed though. The stock t-stat is 203* and the stock fan setting are up around 210-215(I'm sure a techy will chime in on the exact temp). If you have the stock t-stat you don't want to lower your fan settings any lower than like 208 or your electric fans will be running constantly and you may burn them out.
Now if you have a 180* t-stat you can lower your fan settings on the stock tune to something slightly above 185* and you've now lowered your engine temp about 20*. Heat soaked engines are more power robbed.
As for MDS, not sure if you can turn it off in the stock tune or not, but it would be in Performance Tune, Stock Tune, Modify Tune, if anything?
Shift firmness and any of the tranny settings can be "Quick Adjusted" without installing a tune. It can be accessed in the Performance Tunes menu under Quick Adjust.
If you have Diablo Predator why not just load a tune in...you can't go wrong?
2005 Magnum RT AWD 344AWHP/358AWTRQ
FRI Sidewinder Cam, Johan Tune, Edelbrock Headers, JBA Hi-Flo Cats, Magnaflow Catback, 180* T-stat, aFe Stg II CAI, 85mm Throttle Body, SLP 25% UDP, Catch Can, Taylor Shortys, Freak351 Trans Box , Eibach Pro Kit Springs & R1's. Interior, Engine & "M" Emblems by Billet Tech, R/T Emblems, Magnum R/T Grille, Black Heads & Tails, Eyelids
You can go in and select modify tune without loading a tune, on my SLP Predator anyways. You can adjust fan temps[they are set high about 228] you can delete egr, and mds[I lose mpg without mds, but with my exhaust and mds, it sounds sick], there are other adjustments also.
SLP CAI, SLP Catback, SLP 25% underdrive pulley, 170 stat, Predator SLP tunes[2], Mopar TCM, no esp mod.
I believe you have to modify your stock tune.
PPP stage 3 heads, Howards cam 219/227 .600/.575 112 +4, ported 6.1 intake, MMPG 85mm throttle body, MSD "Blaster" coils, JBA headers & mids, Corsa exhaust, Paramount "Dominator" torque converter & stage 2 valve body, BC Racing coilovers, Eibach sways, BWoody links, Razorsedge brace, 226mm Getrag 3.91 LSD, Wilwood "plus 2" big brake kit by TCE
Where can I adjust the shift firmness? I just got my Predator a week ago and I cant remember seeing anything about "shift firmness". Is it labeled under something else?
06 Charger SRT8 - Magnaflow catback - Jet 180 tstat - K&N air filter - Mopar slotted rotors - Centric Posi Quiet brake pads - Predator -
I'm running the "Stock Modified" tune on mine, i think all i have is 6k rpm shift, 6300rpm redline, increased firmness... its still quick... im running midgrade gas right now also.
2005 Dodge MAGNUM RT 13.8 1/4, 100.7mph trap (gone... for now)
1974 Plymouth Duster, daily...
slow engine
slow transmission
slow wheels
