Results 1 to 9 of 9
    BlackRT313 is offline LX Padiwan
    Dec 2008
    Detroit, MI
    Pros/Cons To Rustproofing
    Even though my car will be stored for the winter I was wondering should I get the doors and undercarriage rustproofed? Moisture and dirt will eventually cause rust so I would like to have some protection. The last thing I want is a corroded brown mess under my car. Is there anything I should be concerned about in getting this service done? Is it totally necessary or is it just a matter of keeping the underbody clean and dry? Any advice and comments welcomed.
    Magnum Power's Avatar
    Magnum Power is offline Hypermiler
    Dec 2006
    Upstate, New York
    I had mine done a few months after I bought it in 2006. The only draw back, the engine compartment looks like du-du with the rust proofing all over it. It needs to be done every year so that small holes in the rust proofing doesn't hold water/salt and cause rust to form under the coating. Outside of that, So far I have no rust.
    "Heimes Oppugnamus Et Montes Superamus"
    sound&security's Avatar
    sound&security is online now NOT MADE IN CHINA!
    Aug 2007
    FT LAUDERDALE
    do it your self-all you need to do is the inside of the door bottoms and make sure not to over load the drain holes. than the floor pans just do along the seams were they are joined together.
    Think about how stupid the average person is..
    Then realize half of them are dumber than that
    Dec 2008
    Detroit, MI
    Quote Originally Posted by sound&security View Post
    Is there a special poduct I would need to use?
    desquirrel is offline LX Padiwan
    Jan 2005
    Rahway, NJ
    1) Useless
    2) Causes rust more often than prevents it (car rusts from moisture trapped under the goo)
    stevesrt8 is offline long term car nut
    Feb 2006
    sunny florida
    X2
    a real waste of money. Modern cars are warranted against it and are very difficult to get to rust.
    Just keep it clean.
    Steve
    06 300C SRT8
    Dec 2008
    Detroit, MI
    I think this is good information for anyone considering rustproofing or not. It has good suggestions and tips on care.
    http://www.corrosion-doctors.org/Car...Prevention.htm
    Dec 2008
    Detroit, MI
    Anyone doubting that their car underbody won't rust should take a look in this link showing a new Challenger with rust showing already. Something to think about.
    http://www.jdoqocy.com/click-3193580...tid%3Dcj260233
    Super T's Avatar
    Aurora, IL
    Quote Originally Posted by BlackRT313 View Post
    Body rust and suspension rust are different problems. You pretty much will never avoid suspension rust. Body, however, should not rust unless the paint is compromised. I had "the goo" on my RT - made it unbelievably nasty to work on anything under the car, and the engine looked like turd.
