When you get the flashpaq, check the software versions using the flashpaq and send them to me via pm and I will let you know if there are any updates for your car. Good luck on getting the dealer to do anything about it. You can try and go in with the complaint of shudder or something but unless it does it for them they will most likely tell you that it just does that. Where are you located??
2005 Dodge Magnum R/T
-Martin Luther King, Jr.
