The above write up won't help with his questions, Bubba is asking about parts that are for the sealed intake system. The write up is for the standard installation.
I can help with the rubber plug part, as I asked Mo' about it.
It goes in the stock air box, under the air filter - it seals up the hole where the silencer pipe was.
Mo' also told me to remove any rubber plugs or boots that are under the stock air box, to allow the air box to sit lower under the hood. You also do not use the stock mounting bolt that was on the stock air box.
As for the long thin rubber seal, I have no idea. Maybe it goes under the hood scoop to seal against the base mount plate?
I have not gotten that far yet, I am still painting my Shaker.
Good luck,
Bob
Reason: add info
