Originally Posted by
fnkychkn
since the red dot (security light) comes on, and turning on the headlamps manually with the switch restores headlamp operation, i would suspect a bus failure which would interrupt the ambient light level message. perhaps a loss of communication with the HVAC module. a scan should reveal any loss of communication DTCs that may have been logged. if my suspicions are correct, i'd be checking HVAC module connections.
i'm going to agree that this might be the issue. when Pac-Audio used my car for beta testing some of there stuff, they did not reconnect my HVAC controls (A/C Controls) correctly, that is to say they did not plug the connector all the way in, and when I would hit a hit bump in the road my lights would turn on (like they do when you disconnect the HVAC)...
