Results 1 to 15 of 24
    BlackRT313 is offline LX Padiwan
    Dec 2008
    Detroit, MI
    Painting Calipers: Professional? Or Do It Yourself?
    I was wondering is it better to get brake calipers professionally painted or simply do it myself. I was thinking that it might look better and last longer if someone professional does. Has anyone had their calipers painted at a bodyshop? Am I just simply better off doing them myself? If I try to do them myself should I take them off first? Has anyone painted the wheel hub too? What would be the best approach to this?
    05silvhemimag's Avatar
    05silvhemimag is offline speedjunkie
    near springfield missouri
    i just did it myself to save money and plus i do everything on the car myself just me, but yea people have prob painted the hub black but i dont think anyone has painted it red or anything i wouldnt think unless the wheel is red or blue, ect... but yea if you dont have painting experience then yea if you dont feel confortable doing it then take it to a profesional, but dont waste your money if your going to buy a brake up grade like bembos or baer brakes cus they are already painted and you might as well paint the stock units yourself if your going to upgrade, also you can get caliper paint at oryllies...
    Builder Bill Flywheel, Pro Torque 2800 stall,K&N intake,25%UNDERDRIVE PULLIE, SLP LOUDMOUTH EXHAUST!!!,DIABLO 91 cai tune,ZEX 125shot nitrous ,MSD window switch, talor shorties. DYNATEC SUPERMAXX long tubes, and CATLESS..180 t-stat.Tinted tails done buy me. and lots lots more visual mods...race worrior cam NOT INSTALLED
    386 HP at wheels
    466 tq at wheels
    on 100 shot
    OZarks Raceway Personal best 12.8 at 94 mph, 1.9 60 FT. street tires, Faster times to come!
    Tagman's Avatar
    Tagman is offline LX Guru
    Willoughby Hills, OH
    Not that hard to do yourself and they should last a long time if done right. If you wanted to get them done by a pro, I would suggest skipping paint and get them powdercoated.
    When I did mine I took them completely off, separated the caliper pieces, used a wire wheel to clean them real good, and sprayed several layers of caliper paint. Was a two day process as I wanted to let them dry between coats and wanted several coats. Not something you can rush and now that the weather is getting cooler, will take longer to dry. Also, I did the caps of the rotors.
    But, if you do take them off, just be aware that you WILL lose some brake fluid and you WILL have to bleed your brakes. And that brake fluid WILL take off the paint if you spill some on your nicely painted calipers/rotors. Also, you should get new copper washers for the brake lines.
    You don't have to take them completely off the car to paint them, but I felt this was the best way to get them cleaned properly and I was able to completely paint all the surfaces of each piece.
    You could just remove the calipers from the rotors, remove the brake pads, disassemble the caliper and adapter. The caliper will still be attached to the brake line so take care not to twist of put any strain on the line.
    Sounds like a lot of work and could be a bit intimidating, but just take it slow and easy and take it one step at a time.
    Tagman
    It's TORRED or NOred!
    Super T's Avatar
    Aurora, IL
    Wire wheel and brush and some brake cleaner to clean them really well, some good high-heat primer, and high-heat paint, and you're good.
    Mar 2008
    Or you could get the MGP caliper covers.
    PPP stage 3 heads, Howards cam 219/227 .600/.575 112 +4, ported 6.1 intake, MMPG 85mm throttle body, MSD "Blaster" coils, JBA headers & mids, Corsa exhaust, Paramount "Dominator" torque converter & stage 2 valve body, BC Racing coilovers, Eibach sways, BWoody links, Razorsedge brace, 226mm Getrag 3.91 LSD, Wilwood "plus 2" big brake kit by TCE
    jagger's Avatar
    jagger is offline LX Newbie
    Oct 2009
    Salisbury, North Carolina
    ANy idea of the mgp covers will work with 22" wheels. They look great, little pricey, but look great!
    Tap out or Pass out..... I don't really Care!
    Don't Like Cops? Next time call a crack head!
    www.EARTHSHAKINGENTERTAINMENT.com
    http://www.lxforums.com/board/signaturepics/sigpic32491_1.gif
    SoCalRT's Avatar
    SoCalRT is offline Major Mag Nut
    Lake Elsinore, CA
    Or you could polish them....
    Later,
    Brett
    NWH_300C's Avatar
    NWH_300C is online now LX Padiwan
    Dec 2008
    Northern California
    Quote Originally Posted by SoCalRT View Post
    thats what im doing tomorrow, any tips?
    bac n black's Avatar
    bac n black is online now He who laughs last didn't get it.
    San Diego
    Quote Originally Posted by jagger View Post
    Wheel size has no bearing, they will fit. You can even color match them.
    BT Goodies, Custom Taillight Trim, Challenger Sill Protectors, Bright Pedals, Fender Stripes, LED Interior.
    "Proud Challenger Rallye SE Owner, Looks Fast, All Show (and Performance) and Some Go"
    SoCalRT's Avatar
    Lake Elsinore, CA
    Quote Originally Posted by NWH_300C View Post
    I started with files and ScotchGaurd pads on a die-rinder and worked up to 2000 wet-dry sandpaper and finished it off with the PowerBall and billet polish....
    Later,
    Brett
    Dec 2008
    Detroit, MI
    How did it take you to polish them? Did you clear them after after?
    Dec 2008
    Detroit, MI
    Has anyone painted the rotor hubs black and the calipers red?
    Prospector's Avatar
    Prospector is offline The Old Man
    Cincinnati, OH
    Quote Originally Posted by BlackRT313 View Post
    You're not talking about painting the rotors themselves are you?
    Dual Magnaflows, Ported Throttle Body
    K&N Series 63 CAI, Big Bully Catch Can
    Diablo Predator
    Dec 2008
    Detroit, MI
    Quote Originally Posted by Prospector View Post
    No just the wheel hubs where the rims connect and the top of the rotors where the brake pad doesn't meet.
    07RT's Avatar
    07RT is offline LX Padiwan
    Feb 2009
    SoCal
    Quote Originally Posted by Tagman View Post
    That's what I did and it came out great. I bought a brush-on kit that came with a can of brake-kleen and a cheesy little brush. The results were good, but it was a hassle to do with the brush. If I had to do over I would use the spray can version.
