Results 1 to 9 of 9
    AustinSRT's Avatar
    AustinSRT is offline LX Padiwan
    Dec 2007
    Leander TX
    P0340 code on 2008 SRT w/2600 miles.
    coming into work this morning and saw a light come on and heard a chime, without looking I knew I would need to get gas soon and that that was it.
    Noticed at lunch it was the motor light that was lit, did the code check and it says P0340 for the camshaft sensor circuit.
    Any ideas on what would cause this? Only mod is a corsa catback.
    Rick
    Bornagainultimatum's Avatar
    Bornagainultimatum is offline The Servant
    Nov 2006
    Eastern PA
    P0340-CAMSHAFT POSITION SENSOR CIRCUIT
    ²
    When Monitored:
    During engine cranking and with the engine running. Battery voltage greater than 10 volts.
    ²
    Set Condition:
    At least 5 seconds or 2.5 engine revolutions have elapsed with crankshaft position sensor signals present but
    no camshaft position sensor signal. One Trip Fault. Three good trips to turn off the MIL.
    Possible Causes
    (F856) 5-VOLT SUPPLY CIRCUIT SHORTED TO BATTERY VOLTAGE
    (F856) 5-VOLT SUPPLY CIRCUIT OPEN
    (F856) 5-VOLT SUPPLY CIRCUIT SHORTED TO GROUND
    (K44) CMP SIGNAL CIRCUIT SHORTED TO BATTERY VOLTAGE
    (K44) CMP SIGNAL CIRCUIT OPEN
    (K44) CMP SIGNAL CIRCUIT SHORTED GROUND
    (K44) CMP SIGNAL SHORTED TO (F856) 5-VOLT SUPPLY CIRCUIT
    (K900) SENSOR GROUND CIRCUIT OPEN
    CRANKSHAFT POSITION SENSOR
    PCM
    6.1L Hemi Registry # 00801
    JESUS CHRIST is my President!
    Nov 2006
    Eastern PA
    P0340
    Always perform the Pre-Diagnostic Troubleshooting procedure before proceeding. Diagnostic Test
    1.
    ACTIVE DTC
    Crank the engine.
    Ignition on, engine not running.
    With a scan tool read the DTCs.
    Is the DTC active at this time?
    Yes
    >> Go To 2
    >> Go To 14
    2.
    Turn the ignition off.
    Disconnect the CMP Sensor harness connector.
    Measure the voltage on the (F856) 5-volt Supply circuit in the CMP
    Is the voltage between 4.5 and 5.2 volts?
    Yes
    >> Go To 3
    >> Go To 10
    3.
    Measure the voltage on the (K44) CMP Signal circuit in the CMP Sensor
    harness connector.
    Is the voltage between 4.5 and 5.0 volts?
    Yes
    >> Go To 4
    >> Go To 7
    4.
    Disconnect the PCM harness connectors.
    CAUTION: Do not probe the PCM harness connectors. Probing the
    PCM harness connectors will damage the PCM terminals resulting
    in poor terminal to pin connection. Install Miller Special Tool #8815
    to perform diagnosis.
    Measure the resistance of the (K900) Sensor ground circuit from the
    CMP Sensor harness connector to the appropriate terminal of special
    tool #8815.
    Is the resistance below 5.0 ohms?
    Yes
    >> Go To 5
    >> Repair the open in the (K900) Sensor ground circuit.
    Perform the POWERTRAIN VERIFICATION TEST.
    5. (K44) CMP SIGNAL SHORTED TO THE (F856) 5-VOLT SUPPLY CIRCUIT
    Measure the resistance between the (K44) CMP Signal circuit and the
    (F856) 5-volt Supply circuit in the CMP Sensor harness connector.
    Yes
    >> Repair the short between the (K44) CMP Signal circuit and
    the (F856) 5-volt Supply circuit.
    No >> Go To 6
    6.
    NOTE: Inspect the Camshaft sprocket for damage per the Service Information. If a problem is found repair
    as necessary.
    If there are no possible causes remaining, view repair.
    Repair
    Replace the Camshaft Position Sensor.
    7. (K44) CMP SIGNAL CIRCUIT SHORTED TO BATTERY VOLTAGE
    harness connector.
    Is the voltage above 0 volts?
    Yes
    >> Repair the short to battery voltage in the (K44) CMP Signal
    circuit.
    No >> Go To 8
    8.
    Measure the resistance of the (K44) CMP Signal circuit from the CMP
    Sensor harness connector to the appropriate terminal of special tool
    #8815.
    Yes
    >> Go To 9
    >> Repair the open in the (K44) CMP Signal circuit.
    9. (K44) CMP SIGNAL CIRCUIT SHORTED TO GROUND
    Measure the resistance between ground and the (K44) CMP Signal circuit
    Is the resistance below 100 ohms?
    Yes
    >> Repair the short to ground in the (K44) CMP Signal circuit
    No >> Go To 10
    10.
    Yes
    >> Repair the short to battery voltage in the (F856) 5-volt Supply
    circuit.
    No >> Go To 11
    11.
    Measure the resistance of the (F856) 5-volt Supply circuit between the
    tool #8815.
    Yes
    >> Go To 12
    >> Repair the open in the (F856) 5-volt Supply circuit.
    12. (F856) 5-VOLT SUPPLY CIRCUIT SHORTED TO GROUND
    Measure the resistance between ground and the (F856) 5-volt Supply
    Yes
    >> Repair the short to ground in the (F856) 5-volt Supply circuit.
    No >> Go To 13
    13.
    PCM
    NOTE: Before continuing, check the PCM harness connector terminals for corrosion, damage, or terminal
    push out. Repair as necessary.
    Using the schematics as a guide, inspect the wire harness and connectors. Pay particular attention to all Power and
    Ground circuits.
    Were there any problems found?
    Yes
    No >> Replace and program the Powertrain Control Module per Service Information.
    Perform (NGC) POWERTRAIN VERIFICATION TEST VER - 5.
    14.
    ERRATIC CMP SIGNAL
    With a lab scope probe and the Miller special tool #6801, back probe
    the (K44) CMP Signal circuit in the CMP harness connector.
    WARNING: When the engine is operating, do not stand in direct
    line with the fan. Do not put your hands near the pulleys, belts, or
    fan. Do not wear loose clothing. Failure to follow these instructions
    can result in personal injury or death.
    Wiggle the related wire harness and lightly tap the Camshaft Position
    Sensor.
    Observe the lab scope screen.
    Allow the engine to idle.
    Did the CMP Sensor generate any erratic pulses?
    Yes
    No >> Go To 15
    15.
    ERRATIC CKP SIGNAL
    With a lab scope probe and the Miller special tool #6801, backprobe
    the (K24) CKP Signal circuit in the CKP harness connector.
    Wiggle the related wire harness and lightly tap on the Crankshaft Position
    Sensor.
    Did the CKP Sensor generate any erratic pulses?
    Yes
    >> Replace the Crankshaft Position Sensor.
    No >> Test Complete.
    Doctor No is offline LX Padiwan
    car is brand new let the dealer handle it . good test to see how their service is
    bigkevin20's Avatar
    bigkevin20 is offline I like them natural and heavy!!!
    Oct 2004
    PA
    well good luck I been getting that code for ever along with P0335. If they figure it out can you please pm and let me no.
    HEMI!, Diablo Predator CAI tune SOLD, "GIGANTICAI" CAI, Blastin Bobs 7db , 22" 4inch LIP Velocity VW700 Rims on 265/35s SOLD, Chrome Grill, mirrors, pillars, handles and bumper inserts. Clear LED tails, 15" RE SX Sub, 7" Touch screen Navi, Ipod Control, TV Tuner, LED floor lights and license plate light strip, Reverse Camera,. FTP
    The "Giganticai"http://www.lxforums.com/board/f74/check-out-my-new-gigantic-diy-cai-112170/
    The Mag http://www.lxforums.com/board/f74/hear-my-baby-first-time-pics-75308/
    AustinSRT's Avatar
    Dec 2007
    Leander TX
    dropped it off at dealer yesterday afternoon, wait & see what happens.
    Rick
    AustinSRT's Avatar
    Dec 2007
    Leander TX
    called and said it was ready, cleared code and cycled 3 times and couldn't make it repeat the code.
    Rick
    bigkevin20's Avatar
    Oct 2004
    PA
    Of course I hate that answer. Thats just like if you have a check engine light and when you go there its off so they wont work on your car.
    The "Giganticai"http://www.lxforums.com/board/showthread.php?t=112170
    The Mag http://www.lxforums.com/board/showthread.php?t=75308
    Dealer failed the test of good service ,Just clearing code and could not dupilcate problem is such a cop out. Im sure they did not follow recomended service manual procedure(posted above) for trouble shooting.Most common intermittant electrical fault codes are loose pin connectors. If it happens again print these posts out and take them to the service manager and show him the dissatisfaction with his service and what his tech should look for. This approach is not easy as service managers dont like to be told their job , but sometimes it is the only way to really get your car fixed is to play hard ball.
