2005-2007 REC nav unit is plug and play any Nav unit from any Chrysler car that is an REC
2008 Model Nav unit is an RER as I recall (mygig) and will NOT work as the Canbus system (data network in the car) is different and the connectors are different..
any REC nav unit is plug and play, you need the unit, the NAV antenna, and the dash bezel..
AM/FM and 6 CD changer built in however the Sirrius is an attachment, you need the sirrius antenna, module (brain) and wiring..
all can be had here or on ebay from $650 - $1000 depending on age, condidtion and seller..
