Originally Posted by
Magnum375 Jr.
Thats a decent report, but those deposits and spots do change the shape of the disc, making them warped in appearance. Thats a hard statement to prove, i think its wrong, because mine are warped, you can see where the rust forms after washing, and then go drive it and in the one spot the rust will still be there...thats warped.
Could it be something else? Hub or control arm not being perfectly true? Just trying to think outside the box.
One way to eliminate everything else would be to remove the rotor, turn 180 degrees reinstall, see if the rust disappears then reappears in another spot on the face, if it does it would point to something else, if nothing changes and the rust spot does'nt move than you could be right.
I think people cry "warped rotors" to often without truly identifying the root cause.
There are professionals that say using an impact gun instead of a torque wrench can cause the rotor to appear/feel warped due to uneven torquing of each lug. Another theory is manufacturer run out tolerances are not equal across all brands.
Lots to consider.
Mods so far (in order): Color matched strut covers, fuse panel and washer bottle lid. Shaved rear emblems, Silverstar Ultras, Mobile1 syn. Removed air silencer, AFE stage 2, Sirius Radio, Energy 6.5 doors, Energy 10" sub, R1 drilled/slotted rotors and Quasi quiet pads .
