I am looking for a hidden hitch receiver and transmission cooler for my 300c 5.7L Hemi....
Any vendors here sell these items, I have found the Mopar receiver but I am not to hot on the price.......
Any help would be great....
From Uhaul.com:
Hitches for a 2005 Chrysler 300C
Hitch#75171
Square Tube 2 inch Rec.
33500N/A Black
$170.90
High Performance Heavy Duty Transmission Cooler
$81.00
All high-performance automatic transmission coolers fit both domestic and import vehicles with automatic transmission. Stacked plate construction and brazed aluminum technology provide maximum strength, cooling efficiency and oil rate flow. Easy do-it-yourself, step by step instructions are provided. No special tools needed. Quick connect fittings and hardware included.
- Unique plate-to-fin design allows for effective cooling
- Compact size make unit just right for tight areas
- High efficiency turbulators in each plate directs the fluid for superior heat transfer
- Predrilled mounting plates and push-on fittings make them easy to install
Part number: 13238
Thanks, I saw that one, but I am looking for a hidden or verticle mount hitch receiver so that when not towing anything you can't see it....
The only hidden one is the mopar one,I got a curt industries model as I did not like the mopar price and I frequently tow
Dodge Magnum RT AWD MDH=Jan 19th 2005 7-8pm
Tow package, Midnight Blue, Painted spoiler body colour, Auto headlights, HID lows, Fogs on with Hi beams, SC flash with custom tranny and 91 tune, RER MyGig installed, Tranzformer, Resonators deleted, Custom Stainless intake.
160,000km driven very hard, repairs include replaced front brake rotors and pads $200, rear pads$, ebrake shoes, all 4 tie rod ends $50ea (only 1 was loose), front sway bar rubber bushings $25(first thing to check if front is clunky); 3m refinished headlights WOW $30, 4 sets of tires, 2 tranny filter and flushes,
