Results 1 to 2 of 2
Thread: Navi
    Mudog is offline LX Newbie
    Navi
    Hey guys, I am going to buy a stock navi for my 06 charger. I've been trying to look for a pdf on how to install it. Does anyone know the link?
    LtlDad's Avatar
    LtlDad is offline LX Padiwan
    Nov 2004
    OC, CA
    Typically the new unit will come w/ instructions. If you buy used, it should be "plug and play", although the GPS antenna connection might be integrated into one of the plugs going into the head unit.
    Keep in mind, you will need the bezel, too. It should simply pull away from the dash with tension spring clips. Pull from the bottom, first, pull towards the rear/roof line.
    2005 Mineral Gray SXT
    HAS SOME STUFF...
