My SuperChips data from the track
Just joined lxforums, but have been an active member of chargerforums for some time. Here is a post I made over there last week about my experience at the track, and what happened when I took my 91 Oct tune out...
First trip to the track tonite. Greer Dragway, a 1/8 mile IHRA track in Greer SC at about 950' above sea level.
Got there just as the track opened at 6PM. Man it was hot. Car thermometer said 94 when I got there (but it reads high so it was prolly between 88-90). Kept rear tire pressure at 40psi.
Car has JBA Shorties, Magnaflow cat-back, Mopar CAI and I was running the SuperChips 91 Octane tune. 9800 miles on odo. Since it was so hot I wasn't expecting to run as fast as I hoped and I didn't. Made 4 passes between 6:15 and 7:00 with little/no cool down. Car was already heat soaked from the drive up there from work.
Run 1
RT - .004 (yeah!!)
60' - 2.284
1/8 ET - 9.478
1/8 MPH - 76.333
Run 2
RT - .080
60' - 2.239
1/8 ET - 9.442
1/8 MPH - 77.119
Run 3
RT - .207
60' - 2.273
1/8 ET - 9.512
1/8 MPH - 76.771
Run 4
RT - .014
60' - 2.208
1/8 ET - 9.436
1/8 MPH - 76.847
At this point I decided to take a break and see if I could cool the engine so I opened the hood and let it sit for 30 minutes and watched from the stands. I was disappointed with my times. With headers I thought I'd be around 9.0-9.1 even with the heat. So when I went back to my car I pulled the 91 Oct tune and LOADED THE STOCK TUNE. Here's what happened.
Run 5
RT - .090
60' - 2.354
1/8 ET - 9.789
1/8 MPH - 75.537
Man, that was embarrassing. It felt like a DOG on that run. Bad. So I reloaded the 91 Oct performance tune and went right back into the staging lanes and ran 3 more runs back to back. No cool down except to reload the 91 Oct Perf tune.
Run 6
RT - .156
60' - 2.183
1/8 ET - 9.377
1/8 MPH - 76.858
Run 7
RT - -.001 (redlight by one thousandth!!!)
60' - 2.179
1/8 ET - 9.365
1/8 MPH - 77.078
Run 8
RT - .076
60' - 2.263
1/8 ET - 9.370
1/8 MPH - 77.662
So in conclusion, I know I only ran ONE PASS without the SC 91 tune but that was enough. Especially since the car had cooled for 30 minutes prior to that run and was HOT for the other 7. I was sold on SuperChips (even with my problem - I was one of the cars they killed initially) before, and even moreso now.
And even moreso now I want ported/polished heads, a cam and the high-flo cats.
2006 Charger R/T, Brilliant Black, Mopar CAI, SuperChips 91 Octane tune, JBA Shorty Headers, HHP Hi-Flo Cats, Magnaflow exhaust, 180 t-stat, 25-cent fan mod (track only), 8.920 @ 79.383 (69 degrees and 50% humidity)
1966 GTO (389-4bbl w/670 heads), 1967 original numbers match Firebird 400 Convertible with factory A/C.
