I posted in the Magnum section of the forum, hope I'd get a few ideas of how to fix it without waiting for Monday and a tow to the Dealer. Here is my problem, I disconected the battery and later when I reconnected it reset the auto window feature first. When I turned on the key to reset for the ESB the car started for a few secs then dies. I just installed a catback so thought maybe that had something to do with it. I tried restarting and after the 3rd try NOTHING. THEN I went on the forum and read about the red light on my dash! I did look around and found this:
There are two seperate systems at work here, VTSS (Vehicle Theft Security System/factory alarm) and SKIS (Sentry Key Immobilizer System). the batteries are only used for the transmission of a radio wave signal to disable VTSS (Vehicle Theft Security System/factory alarm).
there is a transponder inside the key which gets excited when in close proximity to the SKREEM/WCM (Sentry Key Remote Entry Electronic Module/Wireless Control Module) antenna (halo ring around ignition key hole). once excited, the key transponder transmits a secret key code to the SKREEM/WCM. this works the same way as MOBIL Speedpass, no batteries required. the SKREEM/WCM will then transmit this secret key code information to the PCM (Powertrain Control Module) to allow engine operation.
if, for any reason (read broken battery clip), the key fob fails to transmit a VTSS signal to the SKREEM, the result will be RKE (Remote Keyless Entry) inoperation and, when opening the driver's door using the key lock cylinder, activation of the VTSS alarm. however, the VTSS alarm can still be disarmed by turning the ignition key on. by doing this (key on), the SKREEM/WCM signal (Sentry Key portion) will disable the VTSS alarm. you may also get a "low battery" warning in EVIC (Electronic Vehicle Information Center).
if, however, the SKIS transponder in the key fails to transmit a valid secret key code to the SKREEM/WCM, the result will be a start/stall condition accompanied by a flashing red dot in the instrument cluster. after repeated attempts, the engine starter will be disabled until the PCM receives a valid key signal from the SKREEM/WCM.
QUESTION: how do I get a valid key signal? I tried pulling the IOD fuse, disconnecting the battery (didn't work), and now have it sitting with the key in the "on" position and a battery charger on it. I'm gonna wait 1 1/2 hrs. ane see what happens. If that doesn't do it then what? I have no car 'till a tow and dealer visit on Monday! Thanks for any help...
