LX Detail Questions
Hello Everyone! Thank you for many years of LH quality. My first 300M saved my life when I was t-boned and my second gives me joy every Saturday at the track.
Question 1: Is the LX Speed/Density or Mass Air Flow (Specifically the 5.7L)
Question 2: The rear differential in the LX ranges FROM a 3.90:1 ratio with the 2.7 liter to a 2.82:1 with the Hemi. Are they all the same model? Is it an independent rear suspension? Just different ring and pinion? Interchangability question here? I see a 3.90:1 behind my Hemi.
Question 3: Is it at all possible to get a European 300C with 155mph speed controller and Pirelli tires in the USA? (Think outside the box because I know the base answer is No)
Question 4: Is it possible to special ORDER the 300C with the Touring wheels?
Question 5: Is there any confirmation OR timetable about a SRT-8 PVO version coming to market in the next 36 months?
Question 6: Does the MDS system use the same 4 cylinders every time it engages or does it rotate between cylinders. If the former WHICH four does it use? What is the firing order?
Question 7: In the Dodge Magnum Specs under the Hemi this footnote appears
"(Footnotes)1 Meets Federal Tier 2, Bin 8 emissions requirements; marketed in California as an ULEV1 (Ultra-Low Emission Vehicle) under cleanest vehicle rules." That footnote does not appear in the Chrysler 300C specs. Why?
Thank you for your time!
Don
downrange@verizon.net
Don
1999 Chrysler 300M
14.674 best ET
