Results 1 to 8 of 8
    STAGE 3 R/T's Avatar
    Jan 2006
    Argyle, Tx
    lights dimming with music
    ok, I am running to amps Rockford Fosgate P450.4 450 watt 4-channel Amp and Rockford Fosgate P1000.2 1200 watt 2-channel. I running with infiniti with components 60.1 from and the kenwood 6x9 in the rear. as far as subs I am using 2 Rockford Fosgate P312D2 P3 2-ohm DVC subwoofers. I have a 5.4 cap (yepp its big might get another amp and sub later) in right now and I notice my lights are still dimming on me... WHY? I just put a OPTIMA yellow top deep cycle battery in it. I was sure that this was gonna solve the problem. Any suggestions
    Token's Avatar
    Token is online now First AWD LX in the 12's N/A
    Center of the LX Universe
    Have you tried swapping out the little thin 8 guage ground wire that goes from the battery to te chassis with something in a 1/0 size, made a difference for me, and only cost a couple of bucks
    12.645@108.18
    JamminWagon's Avatar
    Cheyenne, WY
    Quote Originally Posted by hawaiiHEMI
    Hmm lets see 1650 watts = 264 amps(not including the rest of the car's draw)
    (every 100 watts = 16 amps http://www.the12volt.com/info/recwirsz.asp)
    stock alternator = 160 amps, still wonder why haha
    About the only way to keep the lights from dimming would be to out in a bigger alternator or try a dual alternator. A dual battery setup will allow longer stopped run time.
    Once you hit 160 amps the rest is drawn from the battery. During the low draw(low bass) the alternator tries to charge up the battery. Your deepcell has a slightly higher amp rating. The main + is that the deepcell is made for DEEP discharging with out the plates in the battery getting ruined. This is why when you have a normal battery and have run it down to the jump point a couple of times, the battery wont hold a charge. The plates get sulferized(wrong term but it will do for now) and the plates have less "clean" space to accept the voltage.
    It gets even better, when the alternator is trying to give all it can, it gets hotter. When it get over a certain temp, it ability to supply voltage drops. So the battery has to work even harder. Vicious cycle.
    If you have seen the car audio mags you will mutiple alternators on the heavy duty hitters.
    Jan 2006
    Argyle, Tx
    cool thanks for the info!!!!
    momsrockinride's Avatar
    momsrockinride is offline Be very still and they'll go away
    May 2006
    A little fishing village
    with all that gear ....the lights in MY car are dimming.
    SmoovC's Avatar
    SmoovC is offline M45 Maniac
    Apr 2006
    Graham, Kracka'!
    Depending on the type of music, and who is in the car with you, dimming the lights could be good; kind of sets the mood, I think!
    2006 Infiniti M45: Diamond Graphite Metallic, Premium Package Option Group w/ Mobile Entertainment System, Tein H-Techs & KYB Lowered, Magnaflow Exhaust
    2000 Dodge Dakota C/C R/T: Flame Red 5.9L, 1 of 800 Produced, Belltech Lowered, 20" R/T Replica Wheels, Flowmaster Exhaust
    More pics at:
    Visit us at:
    Jan 2006
    Argyle, Tx
    Quote Originally Posted by Magnum Maniac
    HAHA! Nahh I i have pretty much every type of music blasting and my headlights dim like crazy! just dont wanna be driving at night and my lights dim have a cop pull me over for somethin like that!!!
    SDMagnumRT's Avatar
    SDMagnumRT is offline My maggie did me proud
    Dec 2005
    San Diego..now Syracuse
    You can always go to an alternator shop and they can get you a custom setup. My buddy put an ambulance alternator onto has jeep to run all the extra crap for offroading
    05 Magnum R/T Brilliant Black - 4/25/05 to 1/29/07
