Results 1 to 7 of 7
    injunwiz's Avatar
    injunwiz is online now Haulin' Donkeys!
    Oct 2008
    L.A. (Lower Alabama)
    Lets try again...
    I'd like to add the air pressure sensors to my 05 Magnum RT that didn't have them. If I add the sensors in the wheels as well as the pick-up sensors in the wells will it work? Perhaps with Starscan.... or not at all?
    2005 Magnum RT ALL options! Shaken, STU'd, Paddled, and Dropped! See my HEMI Registry for other mods list: http://www.lxforums.com/board/f76/5-7l-hemi-registry-1090-injunwiz-154589/
    injunwiz's Avatar
    Oct 2008
    40 lookers and no answer yet...
    2005 Magnum RT ALL options! Shaken, STU'd, Paddled, and Dropped! See my HEMI Registry for other mods list: http://www.lxforums.com/board/showthread.php?t=154589
    richd is offline LX Padiwan
    Aug 2008
    AZ
    First thing I think is you need new rims that support sensors.Second unless the TPMS was a option in 05,starscan wont have a program to set the TPMS.
    injunwiz's Avatar
    Oct 2008
    I have 09 Challenger 20" ChromeClad and they will support the earlier style sensors, that's not the problem. The question is more about the fenderwell sensors and Starscan. Who can tell me if 05 Magnum had TPMS option? Thanks for the input though...
    BMWDON's Avatar
    BMWDON is offline I-495 Hater
    Dec 2004
    Southern MD
    bet funky could answer your question, he's the tech wiz here
    -Bill
    Challenger Mods: PWR 393, Mean Street heads, Procharger D1 pushing 11+psi, SHR Nag1, DSS 1400 axles and drive shaft, SHR trans but with Paramount Dominator and stage2 valve body to finally be error code/limp mode free. BBS CH-R's and custom splitter with 2011 front spoiler. AAC SMD halos, 3K fog lights, white stripes, cervini wing, hotchkis springs, custom 10" sub w/ kicker amp, sequential tail lights.
    10.89 on Nitto Invo 315/35x20's @18psi in tires. 1.589 60' too! http://www.youtube.com/watch?v=KeXYxSCI_8A
    Mr. iNCREDIBLE's Avatar
    Apr 2006
    you need the WCM modules, the wiring, and a Cluster that supports the function, a 2006 plus FCM and 2006 plus PCM..
    The cluster.. well you need to find a 2006 cluster that is off a car that had the feature, but there was a software change from 2005 to 2006, so you need to get a 2006 FCM and a 2006 PCM so the 2006 cluster will work in your 2005..
    need the wiring harnesses for the WCMs at each wheel..
    I looked into this when I got my SRT wheels for my 2005 300c.. after figuring out the cost of parts and what it would take to add everything, and the fact it would pretty much void my max care service contract..
    I decided to go after market..
    $150 plug and play and works great:
    http://cgi.ebay.com/ebaymotors/Orang...Q5fAccessories
    I direct wired it to the re-view mirror on the power out that others use for their radar detectors and mounted it just above the mirror with some 3M tape on the windshield..
    injunwiz's Avatar
    Oct 2008
    NO wonder you are Mr Incredible, Thanks for the help!
