Results 1 to 6 of 6
    brimmer is offline LX Newbie
    May 2004
    Brick, NJ
    LX Last chime skim???
    Recently, after I start my C and start moving I hear a chime and the EVIC says last chime skim.
    Does anyone know what this means
    Thanks
    BobCav's Avatar
    BobCav is offline LX Guru
    DOD Contractor/Consultant OCONUS Secret Bunker
    Sentry Key IMmmobilizer. It deters vehicle theft by immobilizing the engine if an attempt is made to start the car without a properly programmed key. Since you're moving, I assume it's working properly. If your key battery was low you would get an RKE Battery Low message (Remote Key Entry). Perhaps the SKIM module has failed diagnostics.
    2005 300C, Black, Corsa Cat-Back Exhaust, AirRaid CAI, Remote Start, U-Connect Mod, Mopar Hidden Hitch, Custom Door Dent.
    May 2004
    Brick, NJ
    Could it have something to do with the remote starter I had installed (non factory but it works with the remotes on my key?
    quarky42's Avatar
    quarky42 is offline LX Guru
    Jan 2006
    Las Cruces, New Mexico
    Which remote starter works with the key fob remote ?
    BobCav's Avatar
    I have the MOPAR remote starter and it has it's own separate key fob...
    When I use it, I get a RKE Battery Low message that clears when I insert the key and turn to on. Since yours is aftermarket, you probably have a SKIM Bypass Module that allows the car to start with the aftermarket remote start. Once it's started, the car realizes that it started without the SKIM and gives you the code.
    May 2004
    Brick, NJ
    I don't remember which one I got. I had posted a thread with the name of it when I received it for Xmas. But it was purchased and installed at AutoImage in East Brunswick, NJ. http://www.autoimagegroup.com/ I'm sure that they could tell you which one was installed in my 300C
