KW/ST/Mopar coilover users...questions
Ok for those that have installed coilovers, I'm finally getting mine installed Friday and had a couple questions....
As far as the height adjustment, where did you finally settle on in the range?
Does the height affect the ride? Say if you adjust it all the way down is it rougher and vice versa?
How hard is it to go back and change the height?
And how much can you reasonably change it before it needs a new alignment?
Ok that should do it. I'm thinking I want to stick as close to my current ride height(Eibach Pro's that settled to about a 1.75 drop) but wasn't sure how much that changed the ride and performance as far as the coilovers were concerned, aside from the lower center of gravity.
Thanks in advance for all the input I'm sure I'll get!!
'11 Charger RT Plus- Bright White
22" II Crave wheels (USW's soon) LMI Hammer intake, 85mm BBK, Mopar Strut braces F&R, Corsa Sport exhaust. Trufiber CF hood, KW coilovers, BT underhood treatment, Custom engine bay covers/paint. Coming soon... ICE and a few more suprises from vendor R&D....
RETIRED -'05 Black Magnum RT
