Originally Posted by
SMK HEMI
This happened to both keys at the same time. I know both keys works in the last week because I used them. Doesn't make sense how that could happen. I'm not that lucky. Anyway I checked the connections and solder joint inside the key and everything looks great. Nothing broken. I cleaned it up with rubbing alchohol, but still not working.
Mr. I, you say the keys need to be reprogrammed just to lock, unlock and open trunk?
well yeah the keys are programmed to the car..
sounds odd that both lost the programming.. it is possible that the wireless control module (WCM) in your car has failed.. in that case it is a warranty replacement issue, unless you have an aftermarket alarm or remote start that is/has caused the interference or failure.
