Results 1 to 9 of 9
    randkcustoms is offline LSx Eater
    Nov 2008
    Question Inside Car show power questoin?
    What do you guys use at indoor car shows for power? I have been looking and cant figger out what I need. I cant have my battery hooked up. Any help and links would be great!
    300magnum's Avatar
    300magnum is offline go ninja go ninja go!!!
    Sep 2007
    san antonio, TX
    im in the same boat!.....someone help us out
    http://s215.photobucket.com/albums/cc271/aaroncustommagnum/ two-tone (electron blue on the bottom and platinum pearl on top), Chrysler 300 SRT8 front clip on a dodge magnum with custom mess grille, complete custom painted door panels/gages/center console/ headrest screens/ engine compartment/ and door jambs. 22in Akuza (Slither) wheels. 7in double din in dash radio, 9.2in monitors in each headrest.smoked tail lights and two 15in speakers.
    Frank@Diablosport's Avatar
    Frank@Diablosport is offline No more point, coupons now!
    Feb 2008
    Boca Raton, FL
    The guy that did my audio install wants to install a show plug. From what I understand they will put something like an extension cord type plug under the car with some sort of converter. All you would need to do is be able to plug it to a wall at the show. It is on a few of there show cars. Only reason I haven’t done it is because we don’t get to many indoor car shows here.
    JNL HYDROGRAPHICS GETTIN' THEM WET, ONE AT A TIME!
    TxCowboy's Avatar
    TxCowboy is offline Ride my famous Murder Ride
    May 2006
    Spring, Texas
    If you just need power for your interior accessories, anything that uses DC voltage, then you could get a marine-type battery and hook it up in place of your in car battery. Or, if you need AC voltage then you still could use the marine-type battery and hook a power inverter up to it ... just make sure the inverter is capable of handling the load you will place on it. Hope this helps.
    Nov 2008
    You cant have ANY type of battery hooked up. Plus it will be running from 9AM tell 7PM, and Its a 3 day show. Im looking for a Converter I belive. Somthing to convert AC to DC.
    05Silver_C's Avatar
    05Silver_C is offline Army Bomb Tech
    Fort Lee, VA
    Check into something like this http://www.kinetikaudio.com/powersupplies.asp
    2005 Bright Silver Metallic 300C (Stolen, Recovered, Sold to another member)
    2007 Yellow Super Bee Charger SRT8 #0960 of 1000
    2009 Modern Blue Pearl Grand Cherokee SRT8
    "Viewed from half a world away, a bomb is a political concern; viewed from less than a foot away, a bomb is just a high-stakes exercise in problem-solving, where making a mistake means a final, terminal education in the physics of expanding gases"
    liltrk is offline LX Padiwan
    Aug 2008
    London, ON
    Battery charger.
    I spent most of my money on cars, motorcycles and fast women.
    The rest I just wasted.
    DA H.N.I.C.'s Avatar
    DA H.N.I.C. is offline Missing in Action
    Columbus, OH
    Get a 60amp power converter. Same as is used on RV's. More than 60amps will change the plug design.
    eldiablosrt8's Avatar
    eldiablosrt8 is offline el diablo srt-8
    Mar 2008
    pleasanton,ca
    i have two 100 amp power supplys and that doesnt cover my lights and stereo and tvs. when i ran my denali i had 5 100 amp power supplies.... i takes alot to run stereo tvs and lights...you will be surprised.... get exspensive real quick too..
    Astron has great power supplies.... the biggest issue is hiding those supplies in the car
