Results 1 to 15 of 22
    McKinneyMagnum's Avatar
    McKinneyMagnum is offline LX Newbie
    Dec 2005
    McKinney, Texas
    I feel stupid...Any trick to removing battery cable from terminals??
    I loosend (then removed) the nut/bolt on the negative clamp, but I cannot get the damn thing off the terminal. I even spread the clamp open a bit, but no go. I dont want to strong arm it too much because it's starting to bend outta of shape. Am I missing something? Thought this would be an easy DYI battery swap.
    2005 Inferno Red RT
    Custom CAI thanks to Frankentake III
    Blastin' Bobs 7db
    Flowmaster Delta 50 Series Mufflers
    LED Eyebrows and Blinker Mod
    McKinney, Texas
    Ultimatecarman45's Avatar
    Ultimatecarman45 is offline otherwise known as UGM
    Timbuktu otherwise known as wyoming
    Shouldn't be anything more to it...I find sometimes that they are notched in when first tightened a bit tight at the factory, you might have to try to swivel it back and forth to get it to break the 'seal' on the tightened notch...they can be tough little buggers. You might also have to pry a bit under them to get it to slide up for you too. Maybe a little electrical lubricant too just in case you got a really tough one.
    Dec 2005
    McKinney, Texas
    I been swiveling back and forth and trying to pry up with flat head, but the actual clamp seems to be taking a beating...trying not to bend it up too much...UGH.
    2005 Inferno Red RT
    Blastin' Bobs 7db
    McKinney, Texas
    well, if all else fails...and you are in a quick jam..some liquid dish soap should help you out in this instance if you can get it into the crack.
    Darthvader is offline 'waste of skin'
    Nov 2005
    Try a needle nose on the back side and rock it back and forth
    36 chambers's Avatar
    36 chambers is offline Banned
    ON A HOLLYWOOD SET NEAR U!!!!
    hammer time!!!!!!!!
    Sonny is offline LX Newbie
    Jan 2006
    SW PA
    terminal
    Quote Originally Posted by McKinneyMagnum View Post
    Just be careful of your eyes. I have a friend that was working on his car and prying with a tool which slipped and struck his eye blinding it.
    Dec 2005
    McKinney, Texas
    ouch...already wearing my safety goggles!!
    2005 Inferno Red RT
    Blastin' Bobs 7db
    McKinney, Texas
    Super T's Avatar
    Aurora, IL
    Wedge a flathead screwdriver in the gap/slot in the clamp, then twist to spread the clamp to make a wider opening.
    INK FIEND's Avatar
    INK FIEND is offline sippin on some sizzurp.......
    cali bitches
    k y or even astroglide will help....ohhh wait......never mind
    RedRiderR/T's Avatar
    RedRiderR/T is offline Quiet Mom!!..I Know What I'm Do'n
    Nov 2005
    Wallingford, CT
    If the battery is NG and it's just going to be a core to be returned, then I'd just destroy the battery post.. like take a 1/2 drill bit and drill down just below where the clamp is then squeeze the lead post with pliers to try to deform it enough so that the terminal will break it's bond...
    or just get crazy like me and break out the sawzall and slice them babies right off!!
    2006 Inferno Red Magnum R/T
    It's got HIR's w/ Nokya Hyper Yellow Fogs, Painted Spoiler, Tinted Front windows, Black SRT grill and SXT headlights...
    Super T's Avatar
    Aurora, IL
    Quote Originally Posted by RedRiderR/T View Post
    You ever bust a terminal off of a battery? It's not so fun, especially if it's in the car! (Gimmie ten beers and I'll sawzall the other post )
    D's300C is offline www.myspace.com/drtyrdr
    Pensacola, FL
    did you get it off yet?
    Color Matched Tails/Handles/Mirrors
    AAC Halos w/color matched housing
    Color Matched Sidemarkers
    Color Matched Trunk Wing
    Demolded/Debadged
    22" MOZ Designer
    Black Grille Craft Mesh Grille
    8000K HID Kits Low Beams and Fogs
    Nav Hack Disc
    22Elite Custom Console Cover
    5% Tint all the way around
    TZ Front Lip
    PS2 w\7" Clarion headrest monitors
    TVNAV2GO
    UAS/Slam Air Bags
    JL Audio in the Trunk
    3 15" Monitors in Trunk
    Tbird100636's Avatar
    Tbird100636 is online now Master ASE Certified NON-Chrysler Tech
    Braintree, Massachusetts
    Cool
    Make sure you loosen the nut almost all the way off before prying in between the splits.
    www.ramtruckforums.com
    Man I hope you got it off...it's been like 5 hours...
