The service manual shows how to determine if they are aimed right, but I can't figure out how to actually adjust then vertically.
I see a horizontal adjustment, but no vertical.
Any help?
Any help?
2005 Dodge Magnum RT - Midnight Blue Pearl
Volant CAI, 190 Thermo, Mr. Grille Vertical Grille,
SXT Headlights, MDS Monitor, Bel 975R,
Infinity 3002cf (dash),Blaupunkt 605 woofer (door), Infinity 6002si (Rear),Infinity Basslink, SC Tuner, GSM Fan/Traction Mod, 22elite Heal Guard, Factory One Tail lights
From the 2005 serviec manual.
OPERATION
The system is designed to automatically level the vehicles headlamps, regardless of cargo or passenger loads or road conditions. When the vehicle is loaded with passengers and/or cargo, as the ignition is turned to RUN, the system will look at the front and rear sensors and make an adjustment based upon feedback from the sensor to see if it has approximately 27.5 degrees from its zero or neutral position. The headlamp stepper motor then adjusts the headlamp up or down for proper headlamp aiming. The system is dynamic. The headlamp level will be adjusted while driving if required based on sensor inputs.
NOTE: If the headlamp leveling module (HID translator module) or sensors are replaced, the system needs to be calibrated using a Scan Tool.
When in calibration mode, the key in the RUN position, the vehicle doors, trunk/liftgate, and hood must be closed.
In addition, no one is seated in vehicle, the vehicle may not be touched (bounced or bumped) until the calibration is complete. The headlamps must be ON to power the stepper motors. The approximate calibration time is 12 - 15 seconds. The scan tool will display a “status of calibration” message. These being either “still in progress”, “passed”, or “failed.”
If a system fault occurs, the translator module will store the Diagnostic Trouble Code (DTC) and enable it to be read using the scan tool and assist in diagnosing the headlamp leveling system.
'Tis a good day indeed when one learns something new about his sweet ride. Thanks the answer maneval, and for asking, snickle.Originally Posted by maneval69
the system referred to in this quote is for euro spec 300. not available in US/canada.Originally Posted by maneval69
Well, hells bells, funky - just when I thought I'd learned something new about this great ride to get excited about you go and splash a dash of reality in here!Originally Posted by fnkychkn
Thanks for the correction.
That does, however, bring us back to snickle's original question: How does one adjust the elevation of the headlights?
(If the answer is simply RTFM, funky, say so.)![]()
Crazy Brits get all the cool toys.... :(Originally Posted by fnkychkn
Sieb
2005 Magnum SXT
no mention of adjustment screws in FSM. as far as i can tell, there is only up/down adjustment. no side to side.
The inner most screw will aim it virticlally. The ont in the top corner closest to the grille? Tighten it and it'll aim more inside.
I havnt aimed mine perfectly yet but everytime I follow mrs grinn to Chilies she tells me which way I need to adjust next. Sure, I could have her stand in front of the car in the carport and direct me but adjusting over a long period of time is a method that has always worked. It's kinda like christmas every trip.
No, they just screwed side to side.Originally Posted by lkd53
Thanks, Grinner. Great info.Originally Posted by grinner
just as was reading about the auto aiming, and getting all exited... I was quickly pulled back to reality ( my neck still hurts). Oh well, thanks for the aiming instructions Grinner. Woulda been kind of neato with the stepper motor and stuff. Think we're looking at a potential mod here? Anyone?
No offense, but I'm glad I don't have all that auto gobbledeygo attached to the back of my headlights. Unless, it was adjustable on the fly from the cabin!
I'd like to aim my lights up a bit as well. The could stand to shine a bit further out.
Displaced Hokie
2005 Dodge Magnum R/T
