Results 1 to 15 of 21
    Redfox0099's Avatar
    North Charleston, SC
    Help Needed .25 fan mod doesn't work...car getting hot
    So I was on my way to the track today (running the 180* tsat as usual) when I notice my car is running around 220*..strange. I pull in to get some gas before the drag strip and when I go to put my .25 fan mod in it doesn't work, either on high or low fan places.
    Can't find my owners manual...what # are the fan fuses?
    Anyone have an idea what might be happening?
    Mr.PEZO's Avatar
    Mr.PEZO is offline Mr.LX Poster !
    May 2006
    Vero Beach / Ft. Pierce
    2006 Charger R/T Midnight Blue, AirHammer, Hood Struts, BT Catch Can, BT Pink Thingy Mod, BMC catch can hose upgrade, FLXC Member
    2011 RAM Crew Cab Outdoorsman- Nav, Remote Start, 3.92 Gears, Alpine Stero, Mopar Bed Rug w/RAM Head, Mopar Black Side Steps, Tint, Weather Tech In Channel Vent Visors
    Redfox0099's Avatar
    Can someone PLEASE look in their manual and tell me which fuses are for the fans PLEASE
    ZMagnum's Avatar
    Tucson, AZ
    70GT6's Avatar
    70GT6 is offline LX Padiwan
    Aug 2005
    IL
    Quote Originally Posted by Redfox0099
    #19 Rad Fan
    #22 Rad Fan Hi/Low
    Redfox0099's Avatar
    thnaks....am kinda stressed..didn't think about the KB...my Bad.
    06SilverSteel's Avatar
    Jun 2006
    Houston, TX
    hey red at least it didnt come from a noob!!
    Redfox0099's Avatar
    I put the wire in like that...like I have 100s of times before...nothing happens... I checked fuse 19 and 22 they look fine to me...any ideas?
    *** This is a photo from the Forum...not of my car but put here so you get the idea***
    ZMagnum's Avatar
    Tucson, AZ
    If you start it up with that particular jumper in place you will get a CEL. Instead jumper the front relay. It puts the big fan on high and no CEL when running the engine.
    But in any case you should have both fans running on low speed with that jumper in place.
    magnuman is offline LX Padiwan
    Jul 2004
    Boise
    When IDSmoker and I developed this mod. last year, we DID NOT jumper that relay. We jumped relay NO. 39, which is the lower one of the two between the vertical rows of fuses on the left of your picture. You have the correct terminals though. I also marked mine (which relay and contacts) with dots of yellow paint, so I make sure I always get the correct one, and hook it up correctly. See the original article and picture:
    25-cent Fan Mod
    magnuman
    Redfox0099's Avatar
    YEah but that one gets too hot and melts the 12 gauge wire shielding so I use the other one
    Hemi31's Avatar
    AuSable Forks,NY/Lorain Oh
    Nathan,wire up one of these and put a switch in the car.
    BFNY PERFORMANCE
    RIP My Friend
    Jun 2006
    Houston, TX
    have you checked the plug on the underside of the fcm, maybe it's loose or worse yet maybe a little melted or something
    Redfox0099's Avatar
    see I don't think yall are getting it...I put the wire into jump the post there and nothing happens. I checked with a test light and one side has power...it doesn't seem feasible to be able to connect s circuit and nothing happen.
    fnkychkn wrote me this...can anyone tell me what that means in English...not Canidian
    "test fuses #22 & #24 using ohmeter.
    with your jumper in place, check for voltage at rad fan connector C1 (4 way) pin 1 (dark green wire with dark blue tracer). should be battery voltage.
    check continuity to ground at rad fan connector C1 pin 4.
    check for battery voltage at rad fan connector C2 (2 way) pin 2 (red wire)."
    Redfox0099's Avatar
    the fan runs when the car is on, I checked. Also when the fan was running I pulled the relay out and put my wire in it's place and it ran with the wire in place...shut off the car and it stopped running...I don't understand, it never did that before.
