Results 1 to 15 of 17
    Magnum375 Jr's Avatar
    Magnum375 Jr is offline First NA 3.5 in the 14's
    Dec 2006
    PA
    Help My dad's demon again!!!
    Ok, I think we have all had it with his friday before christmas/birthday/anniversery/whatever else reason to party car. With all the problems he's had, he could have traded this one in and had an SRT8 already. Now his motor is making this horrible whistling noise. I'm praying that it's a vacumm leak, but it is coming from the EGR area. I checked around for holes in any of the tubing, but nothing. It sounds like a spinning disc or something, sort of like a turbo blow off valve, except he has no turbo. Its a 2005 Magnum RT.....Anyone wanna buy it???? It's got a lot of history. Here is the video.
    RIP Maggie - (Aug 07, 2007 - Dec 04, 2011)
    Leadfootluke's Avatar
    Leadfootluke is online now LX Guru
    Grand Rapids area
    Small animal?
    Sorry Joel and dad, thats some sorta sucky luck you guys have. Good luck.
    HammerStyleIntakeBilletTechBlastinBobTommyZDesign
    Dec 2006
    PA
    My car is fine, his is going in tomorrow for the mirrors getting fixed(wire in the door jam sleve is most likely cut and shorts out the entire power mirrors and left door lock) and now this. I thought maybe an animal at first, but it would have died by now...its been making this noise for about 2-3 weeks now, and it keeps getting louder....Oh, and it could be coming from the top of the motor, specifically at the odd circular spot with the unlabeled dipstick in the middle of the intake manifold.
    dformer's Avatar
    dformer is offline POP'N TRUNKS ON PUNKS.
    Jul 2007
    HOUSTON,TEXAS
    It sounded like a pissed off hamster.LOL...I'm sorry to hear about your issues and wish I coul help.
    If you don't have BT Bling then your not shinnin.
    HemiPowered5700's Avatar
    HemiPowered5700 is offline Raging Inferno
    Mar 2008
    Chi-Town
    That's def. not a vacuum leak...this may sound stupid, but it either sounds like the belt is too long and is slipping under load, the belt is hitting on something like it may be off a pulley a little bit, or maybe the idler pulley is bad on it.
    just my .02....goodluck
    2006 Dodge Charger R/T
    2000 Mercedes E55 AMG
    1991 Cadillac Fleetwood 4.9L FWD
    Dec 2006
    PA
    I didn't think about that....but anything is something at this point......But if it were that, why is the noise coming from the rear of the motor.
    Mar 2008
    Chi-Town
    oh.....hmmmmmmm
    man, i'm drawing a blank. I gotta think about that one.
    ZMagnum's Avatar
    Tucson, AZ
    It's hard to tell where engine noises are really coming from. When my idler pulley went bad on my V6 I swore the sound was coming from the upper part of the engine in the intake manifold.
    That is a really weird sound. I'm sure TBird or Fnky would be able to tell you what it is. If there's no CEL it's probably not too serious.
    ZMagnum's Avatar
    Tucson, AZ
    thewagon's Avatar
    thewagon is offline Hurry up and get here Summer!
    Jun 2005
    Sparks, NV
    sounds like it only happens at a certain range in RPM.
    2005 Inferno Red Magnum R/T & 2010 RAM 1500 4x4 Hemi
    Retired USAF/USANG 22yrs, Det 2 23ADS, 274th CCSQ, 213th EIS
    imahemi is offline ...
    Feb 2007
    Omaha, NE
    ok... question... is the hvac blower running????? it kinda sounds something like that squeaking....
    -Ryan
    -Ryan
    <<<clicky...
    '93 1500 SB - 226k, '05 Magnum RT - 17k, '80 El Camino - 84k
    Dec 2006
    PA
    A/C was off....it gets louder with the A/C on. If I drove it everyday, I could tell you everything, but he drives it. I think the idler pulley or PCV valve would make more sense. I'll wait a little longer before I go look at it again, before it goes to the dealership.
    MoPOWeR-349's Avatar
    MoPOWeR-349 is offline Whiskey Tango Foxtrot: Buster Buster
    Nor Cal
    Louder with the AC on? Definitely sound like a belt issue. What about the intake manifold or various hoses sucking air; cracks, bad gaskets???
    klarmie's Avatar
    klarmie is offline Like Freedom? Thank a Veteran.
    Sep 2007
    New Hampshire
    try running it with out the serp belt on to see if the noise goes away....only a few seconds should tell you if its with the accessory drive system...
    5.7L Hemi Registry # 00814
    Dec 2006
    PA
    Can't now..its in the shop....
