Results 1 to 15 of 22
    cadzilla74's Avatar
    cadzilla74 is offline Does this smell like chloroform to you?
    Jun 2005
    FTW TX
    HELP - Magnum won't start
    So I start my Mag RT up today and get to the end of the block. As I turn onto the main street the Engine Check light comes on and so does a light that according to my manual is the ETC (Electronic Throttle Control warning light. I immediately pull a u-turn and go home.
    In the driveway I shut it off and then try to restart it. It cranks but will not start. I got out the Flashpaq and set it back to stock, (never had a problem before but thought it might make a difference), still cranks but won't start. Also used the Flashpaq to check DTC's and there were none.
    Had it towed to the dealer but they probably won't get it on a lift until tomorrow. Anybody have any idea what's going on here? Can somebody light the FNKYCHKN lamp please? I'm so bummed, this car has been relatively trouble-free and I'd like to get some idea of what the problem could be and also what kind of cost might be involved. 42,000 miles so out of warranty on something like this I would suspect.
    cadzilla74's Avatar
    Jun 2005
    FTW TX
    Bump!!!! Since I posted this in the early afternoon, thought I'd bump it up for the folks just finishing up dinner and logging in.
    GasGunR's Avatar
    Nov 2005
    Romeoville, IL
    Hate to ask the obvious but does it have any gas in the tank?
    PaCharger's Avatar
    Oct 2005
    Supercharged 2012 Audi A6
    just saw the post...crapola Cadz...sorry bud. No clue...I'm sure it'll be a simple fix...but keep us posted. And please tell me the ashtray didn't short out your tcm
    fnkychkn's Avatar
    greasy cardboard box
    did you try the key dance to retrieve codes?
    ZeGuru's Avatar
    ZeGuru is online now It's me, no really - it is.
    Downtown Saint Paul, MN
    Is there a way to find out why the Check Engine light is on without going to the dealership?
    (sorry for hijacking)
    cadzilla74's Avatar
    Jun 2005
    FTW TX
    Both Check Engine and ETC lights are on. Didn't get to do the key dance, tow truck showed up as I was setting Flashpaq back to stock. Flashpaq found no DTC's though....would the key dance have uncovered something else beyond what FP DTC checker would see? And yes, there's half a tank of gas which it has run smoothly on for over 150 miles so I don't think it's bad gas. Also, a large puddle of unknown liquid was under the car, wasn't really pink but since my oil is full and so is my coolant at the correct level my suspicion is my O=rings went on the tranny AGAIN....however dealer says dry tranny would not prevent starting...
    cadzilla74's Avatar
    Jun 2005
    FTW TX
    LMAO Doug....maybe the car is rejecting the ashtray transplant....
    fnkychkn's Avatar
    Quote Originally Posted by StPaulGuRu View Post
    key dance.
    fnkychkn's Avatar
    Quote Originally Posted by cadzilla74 View Post
    not sure of the capabilities of the flashpaq's scanning program. just throwing something out there.
    cadzilla74's Avatar
    Jun 2005
    FTW TX
    Thanks Pete, I appreciate the input, I was checking all my fluid levels and taking stuff out of the car while I was waiting for AAA to come tow it....then it dawned on me I needed to set my Flashpaq back to stock just in case, I was also hoping it might fix the problem although I have never had an issue with a FP tune in 2 years...anyhow, as I finished the reflash and it still wouldn't start I went to the FP menu to retrieve DTC's and it said there were none logged. Right then the tow truck showed up and it was time to go.
    cadzilla74's Avatar
    Jun 2005
    FTW TX
    It appears my car hates the cold as much as I do...the only goofy issues I've had have showed up right when the TX weather does it's annual belly-flop from 80 F to 40 F in one day. The car runs all summer in 100 F heat with no problems and the A/C blowing ice cold.
    Last year, around this same time, I realized I wasn't getting any heat in the car and the Temp gauge wasn't getting all the way up. Turns out, the first time the heat came on the T-Stat stuck open and the car didn't get much hotter than 160-165 F for 3 days until I got it replaced. Last Friday was the first time this year I needed the heater on coming home from work and everything "seemed" OK when I got home but I didn't go anywhere all weekend...it was cold, raining and totally miserable weather here....today I go out to go to work and there's a big puddle under the engine on an otherwise dry driveway and then this happens within 2 miles of driving it. Very strange....
    fnkychkn's Avatar
    you may have inadvertently erased any DTCs when you reverted back to stock tune. best to check for DTCs before flashing it.
    GasGunR's Avatar
    Nov 2005
    Romeoville, IL
    Exactly... I bet it reset the codes when you flashed it:(
    Let us know what you find out.
    Good luck,
    Don
    SeadooSandi's Avatar
    SeadooSandi is offline LX Jetski tower
    May 2005
    On a lake in Texas
    Sorry to hear you're having issues with your car. Sending positive vibes your way. Keep us posted.
    '07 Magnum RT RWD Steel Blue with Road & Track package, NC-SXT silver honeycomb grill, 20" Foose Nitrous Chromes
    Other Rides
    '01 BMW Z3 2.5i Roadster
    Watercrafts:
    '97 Seadoo GTX - Hydroturf matting mod
    '05 Crownline 202 BR with duoprop
    Misc Toys
    2010 Wildcat 31TS 5th Wheel
    The last time I refused a beer I didn't understand the question.
