I keep blowing fuses after i hooked up my fog hids. Stock is 20 amp and i have tried 25 and 30 amp and they keep blowing. Any suggestions? Should i try going higher?
SLP Longtube headers w/ High flow cats, SLP catback exhaust, 170 motorad, Danko Shaker w/ sealed system, powdercoated hoodpins, 22x9 and 22x10 gloss black vipers w/ red stripe, Diablosport Predator, BT oil catch can, along with other BT items, red LED Halos, and killerglass. CMR tune by Josh from HHP. 413.94 RWH - 415.15 ft-lbs torque.
Are you using a relay or is the kit plug-and-play?
sounds like you have something grounding out, that should not happen.
check your wires, make sure that none of the insulation around them is torn..
plug and play. I tested the one side before putting the fascia back together and it worked and then when i installed the other side and turn them on- NOTHING- Blowing fuses. I'll check the wiring again tomorrow.
wired backwards..
flip the connector on the bad one..
i flipped the connector on the one and it worked so i automatically flipped the other. maybe the other connector didnt need to be flipped. I'll try that tomorrow and see what happens.
