Page 1 of 3 123 LastLast
Results 1 to 15 of 32
    Fawn's Avatar
    Fawn is offline 2nd Gen Camaro Lover
    Nov 2005
    Granite Falls, WA
    Question HELP! Blowing Stop Light Fuses
    Ok...so I take the car in to have the wiper switch looked at. They say it's bad, and order the part. That night I have no brake lights at all. So I check the fuses and it's blown. I of course don't have any and I live 20 miles from the nearest store that will have them. So I stole one from the slot identified as "rear fog lamp" hmph whatever that is.
    Then my friend tells me I have no reverse lights. oh yeah, I need to replace that fuse, wonder if that's what "rear fog lamp" was I'm thinking...
    Just now I replace the one I stole and my brake lights were not working again. Sure enough, the fuse is blown AGAIN! What's going on? I still have no reverse lights.
    I can't figure this one out. HELP?!!! BTW, I have NO mods of any kind...so there aren't any aftermarket accessories screwing anything up.
    Fawn
    2005 Dodge Magnum 5.7 HEMI
    Midnight Blue, fully loaded
    (My other car is a 73 Camaro RS 350)
    Hemi31's Avatar
    AuSable Forks,NY/Lorain Oh
    Sounds like they pinched the wire when they put everything back together.
    BFNY PERFORMANCE
    RIP My Friend
    Fawn's Avatar
    Nov 2005
    Granite Falls, WA
    But could they have possibly done anything that would affect my rear lights and fuses??
    Fawn
    Hemi31's Avatar
    The wireing is all under the dash.It's probably all tied together with the switch wiring.The fact that they were playing with that tonight and now you are blowing fuses tells me it needs to go back cause the dealer screwed up.
    BFNY PERFORMANCE
    RIP My Friend
    Fawn's Avatar
    Nov 2005
    Granite Falls, WA
    The fuse I replaced just blew AGAIN. I guess I have no brake lights now. I just called the dealer, I'm taking it back to them tomorrow AM. :( Let's just hope I don't get rear ended between now and then!
    Fawn
    Hemi31's Avatar
    Do your flashers work?
    BFNY PERFORMANCE
    RIP My Friend
    UnderTaker's Avatar
    UnderTaker is offline Bring out your dead!
    Oct 2004
    Norwalk, Connecticut.
    just get it towed - if you live over 2 miles i would not risk it. the dealer should cover it 100%
    05 Blk Magnum RT RWD,Window Tint, Mopar CAI, B&G PCM Flash, Magnaflow Cats, Borla 125, "HEARSE" vanity plate, AR/311 20" wheels W/Goodyear F1 245/45/20, 4X R1 D&S Rotors, LED tails, AAC Halo's suck - replaced with 402 motoring lights (sweet), Custom LED turns, Wired V1 W/Remote Disp, Kenwood Excelon 715dvd w/ NAV, iPod, 2x Diamond Hex 6.5, Eclipse Titanium DVC 12" w/custom enclosure, JL 1000/1, 2x JL 300/2, 2X Optima Batt. w/ Isolator, Rear Shaved, R Sylvania Turns
    Fawn's Avatar
    Nov 2005
    Granite Falls, WA
    I live 45 miles from work. Situation is f'ed up! I will be going home late though, I work my 2nd job tonight, so traffic won't be bad. I don't have any other choice. I HATE MY DEALER!!!!
    Fawn
    Fawn's Avatar
    Nov 2005
    Granite Falls, WA
    hmmmm...the relay is..not sure about the lights...I'll have to check.
    Fawn
    David6ft6 is offline LX Newbie
    Mar 2006
    Spring, TX
    I had that happen to me. I had to replace tons of fuses before I can make it to the dealership. They from a wire that was pinch and replaced it. Been working every since.
    David
    Fawn's Avatar
    Nov 2005
    Granite Falls, WA
    yeah my signals work, tail lights work...just no brake lights and no reverse lights. My wipers work now too! lol
    I dropped it off this morning, haven't heard anything yet.
    Fawn
    PHANTZM's Avatar
    PHANTZM is offline Formerly known as Suipsycho
    Arizona
    Fawn's Avatar
    Nov 2005
    Granite Falls, WA
    o.O ??? huh?
    Quote Originally Posted by Suipsycho View Post
    Gl !
    Fawn
    Fawn's Avatar
    Nov 2005
    Granite Falls, WA
    The dealer just called to tell me it has nothing to do with the work they did with the wiper switch, he says it's completely different circuits.
    Now I'm paying $90/hr for electrical diagnosis. This sucks!
    Fawn
    PHANTZM's Avatar
    Arizona
    Quote Originally Posted by Fawn View Post
    o.O ??? huh?
    Looks like my finger slipped off the shift key.
    GL , good luck.
