Results 1 to 7 of 7
    mkeenan is offline LX Newbie
    Mar 2009
    Hermiston, OR
    HELP ABS Light Blinking and Dinging
    I have a 2005 Magnum R/T and the ABS is dinging. Using an ABS tool I received the following codes:
    C121A Steering Angle Sensor not Initialized
    C100A Left Front Wheel Speed Sensor Circuit
    C2100 Battery Voltage Low
    C121C Torque Request Signal Denied
    C1219 Steering Angle Sensor Erratic Performance
    C121E Brake Pressure Sensor Comparitive Performance
    U0126 Lost Communication with Steering Angle Sen Mod
    I changed the left front speed sensor, checked the wiring into the ABS module, and checked the fuses. Now I have the same codes plus two more:
    U0100 Lost Comm with ECM/PCM
    U140E Implausible Vehicle Configuration Data Received
    Any idea what the problem may be? Any suggestions on where to look?
    Thanks for the input.
    RedHot R/T's Avatar
    RedHot R/T is offline LX Newbie
    Dec 2008
    Newburgh, IN
    May not have anything to do with all of your issues here but, I'm curious what wheel/tire combo you're running and if you have changed anything on the suspension.
    Mar 2009
    Hermiston, OR
    All stock. I just bought the car, so I don't know the true history.
    DonH's Avatar
    DonH is offline Enough and no waste is good as a feast.
    Jacksonville Fl
    Did you do the steering reset thing? All the way left, all the way right, and then center?
    Edit: I believe the exact procedure is in the owners manual.
    Don
    The "UN"club
    We have two rules, Love Cars and Have Fun!
    AirHammer, Zoomers, Predator, 20% Front Tint, GTS Vent Visors, In-Motion Nav Hack, Glove Box Light, Interior Aluminum Door Trim, Billet Catch-Can, Front Passenger Grab Bar .....
    Mar 2009
    Hermiston, OR
    yup, tried it, but still no luck. Very frustrating.
    DonH's Avatar
    Jacksonville Fl
    Maybe PM Fnkychkn, possibly he can shed some additional light.
    Don
    The "UN"club
    Mar 2009
    Hermiston, OR
    Update: long story short. In the end I had the dealership reset the ABS codes, then they test drove it. No more lights, no more beeping, no more codes. Cool.
