Results 1 to 15 of 22
Thread: Help
    ratman1648's Avatar
    ratman1648 is offline Dude, Where's my LX!?!?
    Portland, Tx
    Help
    Help!!! The filler cap for my brake reservoir isn't going back on right/tight and the rubber thingy that goes under the cap appears to be too big
    She will always be missed
    ^^^Somewhere in Houston^^^
    ratman1648's Avatar
    Portland, Tx
    AdamC's Avatar
    AdamC is offline what you need broken?
    Jan 2006
    at the store
    did you try to push the "rubber" back into the cap? sometimes if water is present in the system they will kinda inflate..
    if still no work it's part number 04683656
    ratman1648's Avatar
    Portland, Tx
    Quote Originally Posted by AdamC View Post
    kinda? the thing is HUGE!!!
    ratman1648's Avatar
    Portland, Tx
    any ideas??? This thing is driving me nuts!!
    Super T's Avatar
    Aurora, IL
    They kinda pop inside out sometimes when you take the cap off... pop the lip back into the little clips under the cap and try again?
    ratman1648's Avatar
    Portland, Tx
    tried everything...the dang the just GREW!! It's overall diameter is too big to fit into the cap, no matter how hard I try.
    klarmie's Avatar
    klarmie is offline Like Freedom? Thank a Veteran.
    Sep 2007
    New Hampshire
    sounds like contamination.....I would get it checked as soon as posible!!
    NC-SXT's Avatar
    NC Coast
    Quote Originally Posted by ratman1648 View Post
    Someone has put power steering fluid or oil in it. Get it checked out.
    WWW.DodgeMagnumGrille.com
    ratman1648's Avatar
    Portland, Tx
    Quote Originally Posted by NC-SXT View Post
    ummmmm....errrrrr.....I think that someone was me
    I this something I should worry about? Potential damage(besides the rubber thingy)?
    fnkychkn's Avatar
    greasy cardboard box
    what it did to the cap seal, it will do to all rubber parts in your entire brake system. how long has it been in there?
    ratman1648's Avatar
    Portland, Tx
    too long....comming out friday.
    Gosh I hope I didn't SEVERELY hurt my baby
    fnkychkn's Avatar
    as much as i hate to be the bearer of bad news, this could get quite expensive.
    from FSM:
    BRAKE FLUID CONTAMINATION
    Indications of fluid contamination are swollen or deteriorated rubber parts.
    Swollen rubber parts indicate the presence of petroleum in the brake fluid.
    To test for contamination, put a small amount of drained brake fluid in clear glass jar. If fluid separates into layers, there is mineral oil or other fluid contamination of the brake fluid.
    If brake fluid is contaminated, drain and thoroughly flush system. Replace master cylinder, proportioning valve, caliper seals, wheel cylinder seals, Antilock Brake hydraulic unit and all hydraulic fluid hoses.
    ratman1648's Avatar
    Portland, Tx
    from FSM:
    well unless I start having other problems I will have to wait on changing out the entire brake system....thanks for the heads up
    fnkychkn's Avatar
    at least get the system flushed to help prevent further damage.
