    CURLY's Avatar
    CURLY is offline The Black Pearl
    Jan 2008
    Aurora, Ohio
    Headlight assy removal
    Can sombody tell me how to remove the headlight assy. from Magnum.
    I don't know which screws to remove, and I don't want to change the alignment / aimming screws.
    05' Magnum R/T HEMI Registry #889 CAI, JBA Ceramic headers- CAT back, Mopar TCM, Preditor , MDS indicator, ESP Mod. HALOS
    Aus liebe zum Automobile "Out of Love for the Automobile"
    Super T's Avatar
    Aurora, IL
    There are no alignment screws. Did you search? SOmeone else asked not too long ago, and the link for Grinner's how-to video got posted there.
    At any rate it's easy. Two screws per headlight... one on the top that's real easy to get to if you remove the two-piece black plastic cover thingie on either side of the hood latch (it just pulls up, three clips per side). The other screw is on teh bottom edge. If you pull the six two-part plastic fasteners across the top edge of the fascia that gives you some slack to pry the fascia down. You can use an 8mm socket on an extension... kinda pry down the edge of the fascia under the headlight and you can get to the bolt, it's a straight shot. Have a magnetic pick-up tool handy for WHEN you drop that bolt :-) From there, there's a ball-and-socket type clip on the outer edge that just pulls out of place, then you kinda wiggle it around until it comes out of the opening in the fascia.
    imahemi is offline ...
    Feb 2007
    Omaha, NE
    Here is the link super T was talking about...
    Removing headlight housing
    -Ryan
    <<<clicky...
    '93 1500 SB - 226k, '05 Magnum RT - 17k, '80 El Camino - 84k
